Newbies Queries - Ask and you shall be answered!
#4637
#4638
I go a new motor and tried it out without putting in my car and I held for like 15 sec and it was burning my hand when I set it down. It heats up really fast is there a reason for this
#4639
Your text not very clear. You held yr motor in yr hand. What's the definition of very hot? Motors heat up when used. If you want to see if it's something wrong or not, you need to take its temperature. Unless you're sure what's the temp by feel.
#4641
I have two original Optimas, one belted with brushless running gear and one chain drive I'd like to keep brushed. The chain drive I want to keep brushed has a Novak NER-2S receiver and Rooster Reversible ESC. I would prefer to use an older motor. This car has many modern upgrades and some original upgrades like the hardened final pinion and the OT-74 Limiter Gear Set. I am also using a 3D printed gear set. Its a complete ground-up resto-mod, so pretty much every part that was original is bagged and tagged and replaced with new either kyosho rere parts or new 3rd party aftermarket parts, including the sway bars, turnbuckles, screws, chain guides and servo saver which I modified for greater steering angle.
So I am stuck with a question. I used to run a Kyosho Option House 240WS that got me many a first place wins in the late 80s, but it burned up in a 🔥fire🔥!
I now do not know which motor to put in the car.
I would probably prefer to put a newer motor in it as not to harm my older motors but i do have the rear motor guards so i guess its not that big a deal to use original motors. I have a new Speed Mind 13turn that could work (thinking of getting one a little higher turn like a 16t or higher maybe. I have a newish 15×2 Orion Method SV2. My older motors I've picked out include a Trinity Oval Blast, A 17t×2 Team Checkpoint, a green label Team Associated Competition Off Road Stock motor, and the Twister Red Label with silver lettering or Twister Silver Label with red lettering.
All the motors have been cleaned, proper new brushes per motor, commutators lathed, and magnets have good gauss.
I am not opposed to getting another motor but so far I haven't got the wife on board with me getting a used 240WS as the prices when found are a little steep and I don't have an idea of what else available in the market today would be a good choice.
If you have an idea maybe even pinion gear advice for motors I do have that would also be great.
If anyone has ANY advice it would be GREATLY APPRECIATED! Thank you in advance for even taking the time to read this query.
☆Maturity is the regaining of the seriousness we all had as children at play!☆
#4642
That’s a great idea for a thread! 👍 As for your question, a new stock motor might improve speed, but it depends on a few factors. Even though your old motor has low runtime, age can still affect performance due to factors like demagnetization or wear on the bearings. If your current motor still runs fine, you could try cleaning and maintaining it first before upgrading. What motor are you using? 🔧
#4643
i got a question
I bought a new Nova engine. The settings are factory. When i planted it into my superten, the tyres wont stop moving even when the idle i set was the lowest as well as the high n low end needles. The speed of the tyres were like 1/16 throttle. Moves quite fast on the ground.
1Likes
I found some old RC at home and thought of going to have some fun.
