Newbies Queries - Ask and you shall be answered!
#4486
Hi i am interested in getting a 1/10 EP RC monster truck (traxxas son uva digger from amazon) or a kyosho kobra buggy (RCmart).
the monser truck comes with battery and charger while the kobra do not.
Which one has more parts readily available?
And which one is more recommended?
#4487
#4491
HI guys, i just ordered a HPI savage XS from towerhobbies.
Now i am hunting for a good 2S Lipo batteries preferably higher capacity for longer playtime, any recommendations
Also i found that many batteries from hobbyking do not come with deans plugs.
Can i just get an adapter to fix up the battery? Or where can i get the plugs changed to deans in Singapore?
I would also need a balance charger for the batteries so any recommendation is appreciated.
#4492
Lipos are way better batteries but if u abuse them, they might explode.
Go to any of the local shops and purchase any lipo-compatible charger will do. Make sure it comes built-in balancing port.
Personally, I always balance charge my lipos.
You might want to learn some soldering. It's not too difficult to solder deans.
#4494
I would get any 2s lipo that you can find in any of the local shops. 5000mAh is fine. As per all electric, higher mAh in yr batt does not necessary equate longer runtime. You need to constantly check the temp of yr batt, ESC & motor to ensure they are not heating up too much.
Thanks for the recommendation
#4495
I have got a TT 01 tamiya stock the sad thing is my kis players and got water splash during void deck playing the electronics got wet , I have actually removed everything and open up the RX and ESC drying up but only the servo is working and the TX set to the other mode on throttle can only go reverse on normal mode the car dun run forward ,the problem is the servo is directly solder onto the ESC , and the ESC keeps blinking ,still cannot figured out is it the ESC or the RX, does Stargek sell any replacement any other shop to recommened or should I order from hobby king ? The motor I have check confirm working , but what is the ESC I should use for brush? And should I change to brushless what spec of brushless I must use?
Any kind drifter can help me out pm me ur number or what's app me
Peter 97895334
Peter 97895334
#4497
Hi , I am new to R/C. Am looking at getting one to trial and explore.
I am keen on buggys. Looking for an electronic version and ready assemble.
My buget is around $500-700.
The only ready model I have discovered is the Kyosho DBX VE 2.0 Brushless Buggy from HobbyLink.
Is this good enuff for a newbie?
Any other good recommendations.
Do advise...thanks folks :
#4498
hi, I am rather new to the r/c world and need some advise please.
am interested in getting an electric off -road buggy and for now am looking at an assemble ready out of the box version.
my budget is ard $500-700
so far I have only come across one such buggy from HobbyLink
"Kyosho DBX VE 2.0 Brushless Buggy"
Is this a good choice? Anyone kind enough to recommend or advise futher.
Much appricated
[email protected]
#4499
Much appricated
[email protected]
1Likes
so does anyone knows or would like to sell it to me please text me at 93232947
