V-ONE S Thread
#2026
hahaha
didnt u glue em on phil?
i couldnt be bothered combining
always think of something at the last minute
#2027
whats the part number for the venom pipe?
#2028
I glued jsut kinda dodgely
Umm part number for the venom pipe at radiomodels is VEN0270
and its only $63.8 there compared to about $80 everywhere else so even if thats all you order its still cheaper with postage.
Im hoping it should be here tmoz as they always post so quickly and when i get it ill let ya know how I go
heres a tiny pic from the venom site
Cheers, Phil
Cheers, Phil
#2029
ok thanks maun
are the stingers screw in?
#2030
Originally posted by sausage_link
ok thanks maun
ok thanks maun
#2031
ok thanks maun
ok thanks maun
GT
#2032
ok
thanx for the info fellas
#2033
Does anyone have a tire gluing thingy if so are they any good, I nearly stuck my fingers to my wheel a few times just then. There has to be a better way
#2034
Originally posted by deane
How do i get my car clean???
I am running it rich at the moment(2 turns out) (still on its 1st bottle of 5%) and alot of oil is comming out the exaust. this causes dirt and bits of sand and general crap to stick to the car in all the nooks and cranneys. how do i keep it clean? or clean it properly?
ALSO should i cut a hole in the windscreen for better ventialtion for the motor? it is a supra body. If i cut one in the front windscreen should i cut another in the rear? because there is quite a gap between the ground and the bodyshell at the back and i thought the hot air will just go out that way.
#2035
replace the tube then
#2036
you just squish it and glue comes out. very managable.
#2037
Yeah I got one of those, u can also get exactly the same thing in a superglue brand for about 1/4 - 1/3 of the price which i found out afterwards
#2038
Thx squizzytaylor, got it.......
#2039
Front One-Way Shaft V1S
Squizz, How U doing? I took my v1s out last Sunday and had fun w/ it . It seems that the HPI engien and HPI flywheel w/ some mod works fine on the V1s. The only thing I need to adjust it's the 2 speed. It shift 2early. Anyway can you tell me what the diffrence between the 2 items below. Are they the same
thanks for you help.
Have you guys here or see the new V 1 RR. I think it on my dream list
Front One-Way Shaft V1S P# VZW021
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCYB5
Front One-Way V-One S P# VZW0210
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBXC5
#2040
This's my baby. I am thinking to conver it to a V 1 SRR
