Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 11-01-2008, 08:40 PM
  #14371
bigz's Avatar
Originally Posted by speed freak
Hi, i have just put 18t belts and pulleys inmy cyclone wce and the front belt is a bit tight with the spool bearing holder mark is facing the front of the car and the rear belt is a bit loose with the bearing holder mark facing downwards. Just wondering what is the best position to put these bearing holders in so you get the right amount of tension for the belts.
Depends on the condition of your belts.
bigz is offline
Old 11-01-2008, 09:54 PM
  #14372
Trader Rating: 18 (100%+)
The belts and pulleys are brand new- never run.
speed freak is offline
Old 11-01-2008, 10:55 PM
  #14373
STLNLST's Avatar
Trader Rating: 32 (100%+)
A safe place to start is to put the markings at 12 o'clock. It's a good starting point and the belts aren't too tight or too loose.
STLNLST is offline
Old 11-02-2008, 12:03 AM
  #14374
Thanks for that i will try them at 12 o clock.
Old 11-02-2008, 12:54 PM
  #14375
Registered User
Im building my cyclone TC now and im now working on the shocks. Any tips ? How do I bleed these shocks top cap or bottom.
dannybcaitlyn is offline
Old 11-02-2008, 04:35 PM
  #14376
ngo8's Avatar
just put the bladder on top it should bleed it .
ngo8 is offline
Old 11-03-2008, 10:09 AM
  #14377
bigb11's Avatar
Trader Rating: 59 (100%+)
Anybody looking a blue brushless motor mount for the cyclone. pm me.
bigb11 is offline
Old 11-03-2008, 12:39 PM
  #14378
Trader Rating: 23 (100%+)
Anyone try out the adjustible chasis stiffiners for the optional rear deck etc. I am going to be running carpet rubber with my TC and have the kit yet haven't ran them yet. I know on a foam setup stiff is good but with rubber tires is everyone running a high traction asphalt setup?
Anemic_SluG is offline
Old 11-03-2008, 12:59 PM
  #14379
shadow102's Avatar
Trader Rating: 21 (96%+)
When I switched to indoors I switched to the wce rear heatsink deck sink
shadow102 is offline
Old 11-04-2008, 10:04 AM
  #14380
Talking
Hey guys
I have some questions for you all.
I just bought world edition front solid axle(ver.3) for my cyclone.^^
which drive shaft I need for this front solid axle(ver.3)?
There are so many different versions out there. Please could you all help me out?
thanks,
bara1129 is offline
Old 11-04-2008, 10:45 AM
  #14381
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Originally Posted by bara1129
Hey guys
thanks,
in market drive shaft fit your spool ver.3
RC MARKET is offline
Old 11-04-2008, 12:15 PM
  #14382
can you tell me any part number for drive shaft fit in front solid axle(ver.3)
Thanks,
bara1129 is offline
Old 11-04-2008, 03:29 PM
  #14383
trickd122's Avatar
Default Loose off power !!
Need a little direction here.
I am running the Cyclone Black, I am running 4 degrees droop fr and rear. When off power (no brake) the rear breaks loose. I tried adding more droop in the front same issue.... ANY IDEAS?
trickd122 is offline
Old 11-04-2008, 03:33 PM
  #14384
61388 purple universal bone should fit if you have universals
61396 black universal bone should fit if you have universals
61378 blue universal bone should fit if you have universals
61095 purple mip cvd bone should fit if you have mip cvds
70710 black universal bone will not work.
bionictony is offline
Old 11-04-2008, 03:46 PM
  #14385
yyhayyim's Avatar
Trader Rating: 26 (100%+)
"Trick": What set up are you running? What tires?
yyhayyim is offline
