Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 07-07-2008, 10:29 PM
  #12871
JayBee's Avatar
Trader Rating: 31 (100%+)
Thumbs up You da man!!
Congratulations buddy!!!!!!!!!
JayBee is offline
Old 07-07-2008, 11:31 PM
  #12872
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Korey Harbke
Alright guys... I have a new to HB stuff question. I see most setups for the car call for the 1.1mm 3 hole pistons. I can't find those anywhere here in the US currently... So I was wondering how they compare to tamiya 3 hole pistons??? Thanks!
-Korey
Speedworld has them but before I got mine I was going to try the Tamiya's or the Schumacher pistons. If you stay with 2 hole pistons drop your oil to 30wt. It's as close a feel that you will get to the 3 hole and 45wt some of the set up's have.
STLNLST is offline
Old 07-07-2008, 11:32 PM
  #12873
STLNLST's Avatar
Originally Posted by racenut123
Your not kidding.Jelich and I were out there after work.He realized the front jumps need to change.No flow.95 degrees at 6:30pm means god hates me.BTW is it me or is Rcracing.com down again?
So is the track finished??? If not stop posting and get it done and YES....rcracing is down again
STLNLST is offline
Old 07-08-2008, 12:00 AM
  #12874
Korey Harbke's Avatar
Thanks Clint. I'll have to call down there and see if they'll drop me a set in the mail.
-Korey
Korey Harbke is offline
Old 07-08-2008, 04:00 AM
  #12875
shadow102's Avatar
Trader Rating: 21 (96%+)
any part number on that piston i am looking for them also
shadow102 is offline
Old 07-08-2008, 05:12 AM
  #12876
TheCoolCanFanMan's Avatar
Tamiya 53573 TRF Damper Pistons 3 hole
TheCoolCanFanMan is offline
Old 07-08-2008, 07:16 AM
  #12877
STLNLST's Avatar
you're looking for the HB part number right????
STLNLST is offline
Old 07-08-2008, 07:22 AM
  #12878
shadow102's Avatar
yeah if its available i found the tamiya ones but they arent exactly cheap i would assume the HB ones are cheaper?
Old 07-08-2008, 08:44 AM
  #12879
Apparently the HB ones ar an exact copy of the Tamiya ones
Malc
Old 07-08-2008, 09:22 AM
  #12880
STLNLST's Avatar
you should be able to find the part number on-line but if not try calling speedworld at 11am (916)783-8864 Tell them STLNLST sent ya
STLNLST is offline
Old 07-08-2008, 09:41 AM
  #12881
73524 - Machined Shock Piston (1.1mm 3 Holes/4pcs)
There ya go man, Clint was just too lazy to look
-Korey
Old 07-08-2008, 12:58 PM
  #12882
STLNLST's Avatar
-Korey
Maybe he was too lazy to look. I'm trying to get my mind ready for this weekend. The jedi mind trick doesn't seem to be working in 08. I gotta try something new I may be switching back to the schwartz!!!!
STLNLST is offline
Old 07-08-2008, 01:59 PM
  #12883
USE THE SCHWARTZ!!!!!!
Old 07-08-2008, 02:05 PM
  #12884
RC MARKET's Avatar
Tamiya piston very soft !
RC MARKET is offline
Old 07-08-2008, 02:09 PM
  #12885
Very soft... Do you mean it makes the dampening really soft? Or the material of the piston is really soft?
-Korey
