YOKOMO Touring Car BD-7 >
Like Tree8Likes
Old 03-16-2014, 11:50 AM
  #3826
Trader Rating: 14 (100%+)
Originally Posted by JimmyMac
It feels smoother, but I haven't ran it back to back to compare it yet because I was doing back to back short shock vs standard shock testing. If I have time I'll do that today with the diffs.
does the silicon feel lighter with metal gears? To clearly put it, does a 1000 with plastic feel the same as a 1000 with metal gears? In the Tamiya's, I noticed that with steel vs plastic, you have to run a much thicker oil to get the same feel as plastic gears.
Originally Posted by Racing4Evo
Feels the same on track. I had no problems with the plastic gears either so that money for metal gears should be spent elsewhere.
Agreed. I've been running a diff from my BD5 days, ran it with mod, and still run it today with 13.5 boosted, never had any problems either. Ordered the metal ones out of curiosity. And am still curious hahaha!
mikeygar is offline
Old 03-16-2014, 02:40 PM
  #3827
RAL
RAL's Avatar
Trader Rating: 67 (100%+)
Does anyone know if the stock BD7 RS spring cups fit HPI springs? Or do you need these?
https://www.teamyokomo.com/partslist...ts_b7_s3n.html
RAL is offline
Old 03-16-2014, 02:55 PM
  #3828
Originally Posted by frozenpod
I have the 2014, black shocks with titanium coated shafts. I am surprised they are anything short of exceptional. Would a shim to squeeze the orings be worth a try?
Following up from this I spent several hrs building shocks and trying other orings from other brands of shocks.
From the original yok shocks I have 2 ok shocks (100% stock) that can run little to no rebound without sucking in air, 1 not great but workable shock requires about 25% rebound to prevent sucking in air (slightly better with mugen orings) and one that sucks in air badly with stock orings. It is a little better with other orings but is sill not up to the task.
The best fitting orings were mugen reds followed by kyosho clear.
frozenpod is offline
Old 03-16-2014, 03:00 PM
  #3829
Have you tried the Yok blue oring?
cyclonetog is offline
Old 03-16-2014, 03:04 PM
  #3830
Yes, the shocks have 2 x yok blue oring with the thin spacer.
Old 03-16-2014, 05:45 PM
  #3831
Racing4Evo's Avatar
Are you using black bladders? The clear kit bladders are a one time use kind of part.
Racing4Evo is offline
Old 03-16-2014, 05:48 PM
  #3832
Yes I have the black bladders.
Old 03-16-2014, 07:45 PM
  #3833
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
HPI springs are a direct fit to BD7 Damper, not sure about RS ?
RedBullFiXX is offline
Old 03-16-2014, 08:30 PM
  #3834
I run with my DIY chassis, very good..
asuradahk001 is offline
Old 03-16-2014, 09:30 PM
  #3835
RAL
RAL's Avatar
Thanks DB!
RAL is offline
Old 03-17-2014, 12:05 AM
  #3836
What is DIY chassis? Couldnīt find it anywhere.
desaix is offline
Old 03-17-2014, 02:47 AM
  #3837
DirkW's Avatar
DIY... usually means Do-It-Yourself
DirkW is online now
Old 03-17-2014, 05:36 AM
  #3838
Jorge T's Avatar
Unless the pitch of the plastic vs metal gears are different the oil should "feel" the same. (That is making sure the plastic or the metal gears are not tight in the diff case.)
Jorge T is offline
Old 03-17-2014, 07:54 AM
  #3839
Default Two or four satellite gear
Hi all, have anyone try to use two satellite gear in the rear gear diff on bd7 2014? If yes, in what condition is this setting preferred?
thesaint is offline
Old 03-17-2014, 02:56 PM
  #3840
Shocks appear to be sorted, I found the oring cap was bottoming out before the thin washer made contact with the oring on the 2 not so good shocks.
The 2 orings were just protruding from the shock body so I assume the design was to have the washer press up to the bottom of the shock body applying slight pressure to the orings to prevent movement and leaks.
I removed approximately 0.1mm from the cap which allowed the thin washer to press against the oring and stop air being sucked in.
