Serpent 710
Re: Re: PRICES ON NEW MEGA ENGINES
Originally posted by Sow&Steady
The stuff is available in Houston now Choco?
BTW, you coming to the WinterNats?
Re: Re: Re: PRICES ON NEW MEGA ENGINES
Originally posted by markp27
I wonder where Sow is going next week! at least I know you can't run on the Winternats track, Sow!
Originally posted by SERPENTFREAK69
no,i just talked to Ray at SERPENT USA and he told me that the .21 will come out in November and the .12 will come out in December...but he has the prices and you can pre-pay.....yes,i will be going to the nats ...will you be there?we need to hook up with our cars....choco
Anyone else care to join us?
Re: Re: Re: Re: PRICES ON NEW MEGA ENGINES
Yes Choco, MarkP, Kreidel, Impalabob and me ... plan to be there.
Re: Re: Re: Re: Re: PRICES ON NEW MEGA ENGINES
Julius? Ach no, he's off Skiing Well, we know we can count on Rene and Michael!!!
MS and Rene ... no doubt.
Re: Re: Re: Re: Re: Re: PRICES ON NEW MEGA ENGINES
What??? Skiing? Man ... we were hoping to get free flights there! Now what we gonna do?
Re: Re: Re: Re: Re: Re: Re: PRICES ON NEW MEGA ENGINES
Yeah and he was supposed to pick up D and Crashed on the way!
And Sparksy ...
Its a round-the-world trip ..
Solution to Alu Anti-Rollbar Arms
After installing the alu anti-rollbar arms onto my new 710 and finding that the arms were binding just the same as on my original 710, I decided to take more drastic action this time.
With my original 710, I followed Crashed's advice and lossened the hinge pin grub screws on the front lower arms - worked perfectly, but then the hinge pins move around during a run, so the solution wasn't optimal.
This time, I took the bull by-the-horns and drill out the hole for the hinge pins in the alu anti-rollbar arms. The hole is already 3mm, but I think the tolerance is a little bit tight. After letting a 3mm drill bit slide through the hole a couple of time, I remounted the arms and found that there is no binding anymore There is also no additional play on the arms, so it seems to be a safe and effective fix.
Cheers, Mark.
Cheers, Mark.
[size=4]New build for 710[/size]
New build for 710
Guys, we know some you surf here and don't register or ever post anything. Know that one of the "Tech Elite" here just wrote a comprehensive article on building his second 710.
If you plan to build another one or just thinking of building one then read this!
Originally posted by rcpanama
DRIVE TRAIN: Ball Diff front Medium Soft – rear Medium
SHOCK: Front & Rear Alu with Red Spring / 35 front 3 holes --- 45 rear 3 holes
ANTI ROLL BAR: Front Flat Rear 2mm in (2.5mm)
ROLL CENTER: Front 1mm under - Rear UTI / LT
TOE: Front -1 Rear +2
All in all, I think you should first run the car on that new track first to find what is lacking or too much and then make adjustments to it to compensate.
And yes, don't forget to try the new servo saver if you have it. Good for high speed sweepers.
Re: [size=4]New build for 710[/size]
New build for 710
New build for 710
1. Rear shocktower with old design (gives you opportunity to throw it back to Serpent )
2. New Diff clamp for rear diff
3. Additional 1.2mm shock pistons on top of stock 1.0 mm ones
4. Additional 0.5mm spacers for front roll center
5. Old lower rear arms...
6. Reinforced upper and lower bumper brace
7. Black anodised flywheel
Re: Re: [size=4]New build for 710[/size]
Originally posted by InitialD
Well, one thing about that old "Tech Elite" you're referring to did not get the latest 710 kit. Our friend the ever hip Uncle Crash (another Tech Elite) did up one last week with a new batch of the 710 and check out what he found in the kit;
