Serpent 710
Old 10-19-2004, 08:55 AM
  #17881
Suspended
Default Re: Re: PRICES ON NEW MEGA ENGINES
Originally posted by Sow&Steady
The stuff is available in Houston now Choco?
BTW, you coming to the WinterNats?
no,i just talked to Ray at SERPENT USA and he told me that the .21 will come out in November and the .12 will come out in December...but he has the prices and you can pre-pay.....yes,i will be going to the nats ...will you be there?we need to hook up with our cars....choco
SERPENTFREAK69 is offline
Old 10-19-2004, 09:01 AM
  #17882
markp27's Avatar
I wonder where Sow is going next week! at least I know you can't run on the Winternats track, Sow!
markp27 is offline
Old 10-19-2004, 09:08 AM
  #17883
Sow&Steady's Avatar
Default Re: Re: Re: PRICES ON NEW MEGA ENGINES
Yeah I know ... I wish they'd repaved it already.
Sow&Steady is offline
Old 10-19-2004, 09:09 AM
  #17884
Sow&Steady's Avatar
Yes Choco, MarkP, Kreidel, Impalabob and me ... plan to be there.
Anyone else care to join us?
Old 10-19-2004, 09:12 AM
  #17885
markp27's Avatar
Default Re: Re: Re: Re: PRICES ON NEW MEGA ENGINES
Julius? Ach no, he's off Skiing Well, we know we can count on Rene and Michael!!!
markp27 is offline
Old 10-19-2004, 09:14 AM
  #17886
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: PRICES ON NEW MEGA ENGINES
What??? Skiing? Man ... we were hoping to get free flights there! Now what we gonna do?
MS and Rene ... no doubt.
Old 10-19-2004, 09:17 AM
  #17887
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: PRICES ON NEW MEGA ENGINES
Yeah and he was supposed to pick up D and Crashed on the way!
markp27 is offline
Old 10-19-2004, 09:22 AM
  #17888
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: PRICES ON NEW MEGA ENGINES
That's right!
And Sparksy ...
Its a round-the-world trip ..
Old 10-19-2004, 09:45 AM
  #17889
markp27's Avatar
Default Solution to Alu Anti-Rollbar Arms
After installing the alu anti-rollbar arms onto my new 710 and finding that the arms were binding just the same as on my original 710, I decided to take more drastic action this time.
With my original 710, I followed Crashed's advice and lossened the hinge pin grub screws on the front lower arms - worked perfectly, but then the hinge pins move around during a run, so the solution wasn't optimal.
This time, I took the bull by-the-horns and drill out the hole for the hinge pins in the alu anti-rollbar arms. The hole is already 3mm, but I think the tolerance is a little bit tight. After letting a 3mm drill bit slide through the hole a couple of time, I remounted the arms and found that there is no binding anymore There is also no additional play on the arms, so it seems to be a safe and effective fix.
Cheers, Mark.
markp27 is offline
Old 10-19-2004, 02:40 PM
  #17890
Sow&Steady's Avatar
Default [size=4]New build for 710[/size]
New build for 710
Guys, we know some you surf here and don't register or ever post anything. Know that one of the "Tech Elite" here just wrote a comprehensive article on building his second 710.
If you plan to build another one or just thinking of building one then read this!
Old 10-19-2004, 07:59 PM
  #17891
InitialD's Avatar
Originally posted by rcpanama
DRIVE TRAIN: Ball Diff front Medium Soft – rear Medium
On a high speed track, you may want to try and harden the front ball diff. Front harder than rear. Best would be to go with a oneway front if the track needs very little braking and needs high speed corners. With a oneway front, the rear diff likes to be hardened a little.
SHOCK: Front & Rear Alu with Red Spring / 35 front 3 holes --- 45 rear 3 holes
I would not know if this shock combo would work. Try it out first and if it does not, then use 35wt oil, red springs all around with 3 holes front and rear. That should be a neutral setting.
ANTI ROLL BAR: Front Flat Rear 2mm in (2.5mm)
Try and use the new harder 2.5 mm sway bar. It should work good with oneway or front ball diff. You may want to adjust the front sway bar to harder to take out steering and balance the car.
ROLL CENTER: Front 1mm under - Rear UTI / LT
If the rear swings out a little, try UTI / LB. If you want the car to react faster left to right, use NO shims under the front upper arms.
TOE: Front -1 Rear +2
To get more on power steering, you may want to try less rear toe in like +1.5 or even +1.
All in all, I think you should first run the car on that new track first to find what is lacking or too much and then make adjustments to it to compensate.
And yes, don't forget to try the new servo saver if you have it. Good for high speed sweepers.
InitialD is offline
Old 10-19-2004, 08:01 PM
  #17892
InitialD's Avatar
You know Onkel Sow... Always like to be one step ahead of everybody if he could.
InitialD is offline
Old 10-19-2004, 08:26 PM
  #17893
InitialD's Avatar
If we do go, we will go as drivers and not full time bodyshell painters, cutters, cleaners and mechanics.
InitialD is offline
  #17894
InitialD's Avatar
Default Re: [size=4]New build for 710[/size]
New build for 710
Well, one thing about that old "Tech Elite" you're referring to did not get the latest 710 kit. Our friend the ever hip Uncle Crash (another Tech Elite) did up one last week with a new batch of the 710 and check out what he found in the kit;
1. Rear shocktower with old design (gives you opportunity to throw it back to Serpent )
2. New Diff clamp for rear diff
3. Additional 1.2mm shock pistons on top of stock 1.0 mm ones
4. Additional 0.5mm spacers for front roll center
5. Old lower rear arms...
6. Reinforced upper and lower bumper brace
7. Black anodised flywheel
InitialD is offline
Old 10-19-2004, 08:40 PM
  #17895
crashed_1's Avatar
Default Re: Re: [size=4]New build for 710[/size]
Ummm...correction to item no. 4. It's actually Imm spacers plus the original 2mm ones.
crashed_1 is offline
