Serpent 710
Re: Re: 2 Liters already gone!
Originally posted by Julius
Good to hear your car is working for you.
I had a close look at the pictures and it seems to me the cooling head is 90 degrees off. The cooling slots in the head meant for airflow over the plug are not aligned front to rear....
BTW: Are you going to the 200mm International @ MACH. I plan to make the trip - you'd better get some practice in Oh man, I'm doomed!
Originally posted by markp27
2nd
2nd
Originally posted by Picard
Mark where did you get the CF bumber plate and is the lower plate CF as well?
http://shop.the-border.nl/customer/p...cat=539&page=1
The bottom part is original - I just liked the look of the carbon for the upper plate plus those Titanium screws (they are from Tamiya)
Re: Re: Re: Tires
Originally posted by PSI Racing
Give me a link, and I'll check them out.
Re: Re: Re: Re: Tires
Originally posted by redsand
Zac tires wont fit onto 710. Gotta put some .5mm shim on the axle. That's what I don't like about it.
It's the 3 racing part:
Thanks for the link, is the bottom plate available as well?
Well I will be adding that to the shopping list
http://shop.the-border.nl/customer/home.php?cat=539
Becareful with the 3-Racing parts - the aluminum is very soft! I half stripped a screw in the aluminium supports for the carbon upper plate and I wasn't using so much force
Cheers, Mark.
Thank for the info mark i will check it out
Re: Re: Re: 2 Liters already gone!
Yep! This car is amazing!!
WOW! I hadn't realised that it was aligned for a certain direction Thanks for point this out I did take the head off to see if the liner was nicely run in.
Maybe I'll have time to stop by and say hi on saturday...
Re: Re: Re: Re: 2 Liters already gone!
Originally posted by Sow&Steady
If you do, I'll lend you my video camera ... take some movies for 3Hobby.Com
Unfortunately work has me tied up that weekend. I'll attend the LRP challange in Luxemburg though.
LRP sounds almost electric!
Re: Re: Re: Re: Re: 2 Liters already gone!
Have fun at Heemstede. Rene improved the fastest ever lap with 200mm to 16.117 So you know what the target is
Re: Re: Re: Re: Re: Re: 2 Liters already gone!
It does actually. But they also take care of the HPI races, and they are running efra-open and invitational calsses at the same weekend.
