Mugen MTX-3
#3511
Perfect spacer for clutch bell
simply use one of the thrust washers with the groove in. obviously you will not be able to use the one one the car, buy another!!
#3512
2nd-Gear Spur bearing
Have any of you guys having problem with the 2nd-gear spur's bearing dislodged from its housing? We seems to have a common problem of it here in my place. There is about 4-5 MTX3 owners having the same problem. Any way to solve this? Is this a production fault?
#3513
yep push it out then refit with good locktite
#3514
eddie the fish
eddie did you get my pm about that bookstore on lillte tokyo,thanks
#3515
Originally posted by puma1824
Which brand/manufacturer aluminum servo horns are everyone using?
Thanks,
Puma
Thanks,
Puma
#3516
Any difference between Nova turbo plug no 6 and RB turbo plug no 6 except for its color?
#3517
Re: absolute must haves
Originally posted by hicheef
Whats Up All,
Just cracking open the box and looking so forward to putting this thing together!!! I made sure I spent some times reviewing the pages of this thred(up to page 48 so far) I know about the brake thing the wheel offset thing and Damn the gearing thing went on for days!!!! ANYHOW, I know somebody posted (can't find it) but before this thing hits the track for the first time, besides arms, what are the absolute, have to have because they might break, spare parts?? Any input is appreciated!!!!
Kevin
Setups appreciated too
Foams(shores, company) big track, parking lot, VHT.
Whats Up All,
Kevin
the stock setup is a very good starting point for further fine tune to suite your driving style and your track. you might want to get a 2.5mm rear sway bar as well, this helps you get more steering.
#3518
Originally posted by RClover
just got the Q-world ones, its strong but the hole is a little too small and need to enlarge it to fit the screw...
#3519
Originally posted by Speed De
What would you guys say if I tell you that my LHS wants to sell me the MTX-3 for 800$??? Pretty funny . Maybe I won't be able to drive it after all.
#3520
Originally posted by Corse-R
Sheesh! how I envy the adjustable diff of the Snakes. :battman:
The ones that are fully adjustable externally is the FPS diff.
#3521
rody 5 port modified
hello what pipe should i use on this engine ,rb,nova??????,also do you guys think is worth having these engine modified even more,may be a murman or smeltz rody modified?????? im new at these so for sure im going to blow these engine up
#3522
japan hobby store
manticore do you know of a japanese hobby store that will take orders from the us,im looking for the latest parts from kawahara,racy,m-speed etc.......
#3523
Re: japan hobby store
#3524
hobby shops
thanks manticore for the prompt response ,do you know where can i ge t the latest stuff from kawahara
thnaks
thnaks
#3525
Re: hobby shops
thnaks
thnaks
