Mugen MTX-3
Old 04-29-2003, 01:44 PM
  #3511
Thumbs up Perfect spacer for clutch bell
simply use one of the thrust washers with the groove in. obviously you will not be able to use the one one the car, buy another!!
Cartman is offline
Old 04-29-2003, 03:11 PM
  #3512
kaikiok's Avatar
Default 2nd-Gear Spur bearing
Have any of you guys having problem with the 2nd-gear spur's bearing dislodged from its housing? We seems to have a common problem of it here in my place. There is about 4-5 MTX3 owners having the same problem. Any way to solve this? Is this a production fault?
kaikiok is offline
Old 04-29-2003, 03:14 PM
  #3513
yep push it out then refit with good locktite
Cartman is offline
Old 04-29-2003, 05:17 PM
  #3514
Default eddie the fish
eddie did you get my pm about that bookstore on lillte tokyo,thanks
rcdubs is offline
Old 04-29-2003, 07:09 PM
  #3515
RClover's Avatar
Originally posted by puma1824
Which brand/manufacturer aluminum servo horns are everyone using?
Thanks,
Puma
just got the Q-world ones, its strong but the hole is a little too small and need to enlarge it to fit the screw...
RClover is offline
Old 04-29-2003, 07:29 PM
  #3516
RClover's Avatar
Any difference between Nova turbo plug no 6 and RB turbo plug no 6 except for its color?
RClover is offline
Old 04-29-2003, 07:36 PM
  #3517
Manticore's Avatar
Default Re: absolute must haves
Originally posted by hicheef
Whats Up All,
Just cracking open the box and looking so forward to putting this thing together!!! I made sure I spent some times reviewing the pages of this thred(up to page 48 so far) I know about the brake thing the wheel offset thing and Damn the gearing thing went on for days!!!! ANYHOW, I know somebody posted (can't find it) but before this thing hits the track for the first time, besides arms, what are the absolute, have to have because they might break, spare parts?? Any input is appreciated!!!!
Kevin
Setups appreciated too
Foams(shores, company) big track, parking lot, VHT.
stock a couple of front belt, arms and knuckles.
the stock setup is a very good starting point for further fine tune to suite your driving style and your track. you might want to get a 2.5mm rear sway bar as well, this helps you get more steering.
Manticore is offline
Old 04-29-2003, 07:38 PM
  #3518
Manticore's Avatar
the Q one has poor finishing quality. I forget what brand alloy horn I have but it does have excellent finishing and quality.
Old 04-29-2003, 07:44 PM
  #3519
Roger's Avatar
Originally posted by Speed De
What would you guys say if I tell you that my LHS wants to sell me the MTX-3 for 800$??? Pretty funny . Maybe I won't be able to drive it after all.
I would say, " Does that come with a MR-12, a KO propo Mars radio, along with digital servos, a gallon of 30% Byron fuel, and funds to pay for my first race ." If they say no, " Then they are smoking crack.
Roger is offline
Old 04-29-2003, 09:20 PM
  #3520
InitialD's Avatar
Originally posted by Corse-R
Sheesh! how I envy the adjustable diff of the Snakes. :battman:
Don't be... The ones that come on the 705 are really not adjustable friendly. You need to physically take out the rear end and the ball diff when you adjust the ball diff because the grub screw on the other end loosens and you will end up with 2WD... Every time when you adjust the diff, you need to tighten the grub screw so that the settings don't run.
The ones that are fully adjustable externally is the FPS diff.
InitialD is offline
Old 04-29-2003, 09:24 PM
  #3521
Talking rody 5 port modified
hello what pipe should i use on this engine ,rb,nova??????,also do you guys think is worth having these engine modified even more,may be a murman or smeltz rody modified?????? im new at these so for sure im going to blow these engine up
rcdubs is offline
Old 04-29-2003, 09:26 PM
  #3522
Default japan hobby store
manticore do you know of a japanese hobby store that will take orders from the us,im looking for the latest parts from kawahara,racy,m-speed etc.......
rcdubs is offline
Old 04-29-2003, 09:52 PM
  #3523
Manticore's Avatar
Default Re: japan hobby store
I am not from Japan so I cannot give you any idea about hobby shops in Japan.
Old 04-29-2003, 10:00 PM
  #3524
Default hobby shops
thanks manticore for the prompt response ,do you know where can i ge t the latest stuff from kawahara
thnaks
rcdubs is offline
Old 04-29-2003, 10:21 PM
  #3525
Manticore's Avatar
Default Re: hobby shops
thnaks
Harmony hobby shop in HK.
