Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 10-28-2015, 07:19 AM
  #10051
boudin4evr's Avatar
Trader Rating: 18 (100%+)
i need help
I read a long time ago about shock perches coming off in the front
fixes?
thanks
boudin4evr is offline
Old 10-28-2015, 07:38 AM
  #10052
Team Tekin
yzracer758's Avatar
New Parts from HB for higher traction/turf conditions-
12.5 and 15 Degree Caster Blocks: http://www.hpiracing.com/en/part/115751
+6 MM Carbon Chassis and extended top decks: http://www.hpiracing.com/en/part/115753
#6 Ackermann Arm Set: http://www.hpiracing.com/en/part/115756
yzracer758 is offline
Old 10-28-2015, 07:46 AM
  #10053
skrichter's Avatar
Trader Rating: 13 (100%+)
Originally Posted by Lexicus
I converted the front of my car over. AE Ballstuds and HD Cups
https://goo.gl/photos/249ccXgCEKEWj97x6
Takes a little play out of the front.
Which Finnisher JC kit did you steal your turnbuckles from? Obviously they seem to be a great fit.
skrichter is offline
Old 10-28-2015, 10:16 AM
  #10054
Maybe I'll wait for this as a solution for higher grip astro tracks. Any guess on when this will come to market? Or should I just get the Avid aluminum chassis in the meantime.
Vincent_Diesel is offline
Old 10-28-2015, 10:47 AM
  #10055
Team Tekin
yzracer758's Avatar
These parts should be currently available as team drivers have had access to them for a month or so now...
Old 10-28-2015, 12:08 PM
  #10056
RENOV8R's Avatar
Originally Posted by boudin4evr
i need help
fixes?
thanks
Drill a hole in them and ziptie them to the spring. Also keep the slot in them facing to the rear, they won't come off as often. Exotek makes an aluminum set that seem to stay on better
RENOV8R is offline
Old 10-28-2015, 02:01 PM
  #10057
rcgod's Avatar
Trader Rating: 33 (100%+)
Any idea where? I can't find the caster blocks anywhere online.
rcgod is offline
Old 10-28-2015, 02:27 PM
  #10058
My D413 was hooked up when our local track had low-medium grip indoor clay. We now switched over to astro and I am struggling with my setup. I am currently using Ty Tessmann 2015 IFMAR Astro setup:
Love to hear your thoughts about the carbon fiber chassis on high grip astro. With the CF chassis it just feels like it lacks control around the track. It feels very twitchy / sensitive. Overall it feels inconsistent especially around corners where it feels like grip is not linear. Both my RB6 and SC6 have aluminum chassis and they are very consistent and easy to drive -- but I love my D413 and would love to get some pointers.
Is stock CF chassis NOT the ideal choice for me, and would the AVID aluminum chassis be better for my medium sized high grip astro track? Is the price justified?
4wd on Astro is a LOT more direct than indoor clay from what I have experienced. Regardless, I found the Avid chassis a lot more stable and predictable than kit, esp with the brass weight in the rear.
Diff oils tuned to suit, my preference is 10/300/7. Copper front roll bar, silver rear. Go to silver front if very grippy. If you mount the front shock tops on the inner hole, the steering response should be more predictable/docile. C/F wishbone inserts all round. Tyres on Astro also make a huge difference, what are you running?
I've just picked up the schelle +4 alloy chassis to run this weekend so we'll see how it behaves; currently pitches around a lot on high grip which can make for a challenging drive.
Btw, I race in the UK.
TobyStephenson is offline
Old 10-28-2015, 02:33 PM
  #10059
Team Tekin
yzracer758's Avatar
I suggest contacting HPI directly and see what they say, they should know where they have been shipped.
Old 10-28-2015, 04:42 PM
  #10060
rcgod's Avatar
Will do thanks!
On another note, are most guys running glued plastic inserts in the arms on med bite clay or cf?
rcgod is offline
Old 10-28-2015, 06:20 PM
  #10061
Greetings and thanks for the advice. I have a sneaking suspicion that you may know a thing or two about setting up for Astro : )
I am running Schumacher yellow mini pins on all fours. Please let me know about the schelle +4 alloy chassis. I may consider that as well. Also thank you for the tips above. Cheers!
Old 10-28-2015, 09:02 PM
  #10062
Fabulous's Avatar
Trader Rating: 42 (100%+)
Attached Thumbnails Hot Bodies D413 1/10 4WD Buggy-d413.jpg
Fabulous is offline
Old 10-29-2015, 12:16 AM
  #10063
R1Joel's Avatar
^^ Very nice.
I just got a new body for mine:
R1Joel is offline
Old 10-29-2015, 05:12 AM
  #10064
Trader Rating: 68 (100%+)
I know some guys that are removing 2 spider gears from the front and rear diffs in their 44.3 anyone tested that in the d413?
Speedychris22 is offline
Old 10-29-2015, 11:49 AM
  #10065
nitro2be's Avatar
Originally Posted by R1Joel
^^ Very nice.
That is super sick!. I've seen your other ones like that in the silver and blue I think. Love it. I just might have to copy some day.
nitro2be is offline
