Serpent to 1/10th EP Touring Kit S400 >
Old 03-23-2008, 04:48 AM
  #1441
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
here is Jaris A main setup from nats
http://molzermoweryracing.com/downlo...srubber135.pdf
I recommend in the gear on low bite even as thin as oneway lube, the diff will be very free and really help hook the car up.
ammdrew is offline
Old 03-23-2008, 09:30 AM
  #1442
Randy Caster's Avatar
Trader Rating: 47 (100%+)
What's up guys, finally got to run my S400 last night for the first time. The car worked awesome, really one of the best cars I've ever driven, and that's just on the first day. I'll try to post my setup in the next couple days, but there are a few changes I still need to make.
Randy Caster is offline
Old 03-23-2008, 09:32 AM
  #1443
One note, and something you guys could try out. The car was double steering going into the high speed sweeper. Normally I'd just try more rear end pack in the shocks, but already had quite a bit. I cut out the top deck a little bit to allow the car to flex more, and the double steer went away almost completely, and the car was much easier to drive around the entire track, I'll get some pics up soon as well.
Old 03-23-2008, 10:21 AM
  #1444
TeamButter's Avatar
Good job Randy......I think we are gonna be in good shape for the Nats and Reedy...
TeamButter is offline
Old 03-23-2008, 12:16 PM
  #1445
Definately.. Got plenty of steering without having to do anything too crazy.
Old 03-23-2008, 03:08 PM
  #1446
yyhayyim's Avatar
Trader Rating: 26 (100%+)
S400 Top Deck: It would be nicer to see Serpent working on a revised Top deck....2mm and narrower for more flex on asphalt racing
yyhayyim is offline
Old 03-23-2008, 09:35 PM
  #1447
TeamButter's Avatar
More traction? You must be nuts!!
Old 03-23-2008, 09:49 PM
  #1448
The cut I made in the upper deck didn't give the car more traction, it just made it a lot easier to drive..
I'm trying to post my setup that I used yesterday on the editable setup sheet on the serpent site. I'm on a mac, and I can enter text with no problem, but trying to select options like camber link location etc doesn't work. Anyone have an idea of how I can make it work so I can get the setup posted?
Old 03-23-2008, 10:41 PM
  #1449
Moderator
pc9840's Avatar
Randy - Try to update your version of acrobat reader. I just downloaded the sheet to my wife's mac and it worked good. I was able to select all the options.
pc9840 is offline
Old 03-24-2008, 01:10 AM
  #1450
Kschu= well, you will find the big difference between bl and brush. Bl is really great... Im waiting for my gear diff and I think the stock thrust bearing is the problem of ball diff loosening during races. But, I try to follow the way you set up your ball diff. Did you put some threadlock in your servo saver screw(countersunk) under the chassis to keep them from getting loose?
Sir Butter, thanks for the advised regarding gear diff. Our local track is a little tight with some good sweepers.
At the moment, were using a layout which is similar to the TITC in a certain extent and were running CCW...The guys here who went to Thailand proposed the TITC layout. My query is that, what could be the best diff oil viscosity range in this asphalt track?
Rhoby 1257 is offline
Old 03-24-2008, 03:58 AM
  #1451
Hi,
do you have cut your upper deck in the center ?
Manu_05' is offline
Old 03-24-2008, 07:04 AM
  #1452
Ok, sounds good, I'll give that a shot today! Thanks.
Old 03-24-2008, 07:05 AM
  #1453
Originally Posted by Manu_05'
Hi,
?? I did cut the upper deck, I'll get pictures posted soon.
Old 03-24-2008, 12:53 PM
  #1454
yyhayyim's Avatar
Pics Randy?
yyhayyim is offline
Old 03-24-2008, 01:03 PM
  #1455
I would have had everything up last night, but I'm just all out of order. The setup sheet didnt work on my old version of Acrabat, and the battery in my camera was dead, lol
