Tamiya mini cooper
Weird. I posted this earlier, but it disappeared. So...if you look on the 3Racing site, all of the rebuild parts, including the case for the M05/06 oil filled diff, are Sakura part numbers. Bingo dingo! Look at the bottom of the page.
TA06 diff wont fit in a mini... they're of different size and pitch...
The narrower one is a spool made for the XV01TC
The 3Racing diff works fine in a Mini as long as you run it in A LOT. The standard seals are badly sized and need a lot of breaking in. Locally we've found that a well sorted gear diff is always faster than a ball diff by a couple of tenths a lap.
The TA-03 ball diff will fit.
Spec-R has also gear diffs for M05/06.
I have 2 3-Racing ones in my M05 RA and my M06 Pro,
and Iīm really happy with them. Especially on my M06, where the diff has already done 6 Races and practice without leaking or any trouble.
The blades make it perfect. I hope 3-Racing will restock these.
Maybe I will also order a Spec-R diff for my other M06 this season.
BR,
Matthias
Questions were about gear diffs.
BR,
Matthias
BR,
Matthias
the side plate is specially made for the Mīs from alloy and a special spacer for the other side.
Br,
Matthias
So, to stay TCS-legal, one must run Tamiya springs.
I'll be running the Tamiya PN 54000 aluminum shocks in an M05, mostly on asphalt.
Which Tamiya spring kit is the best one to get?
Tamiya 53333 Short Spring Set.
I run an M03 and for several years I ran the Tamiya ball diff. Everyone was telling me the ball diffs strip, but I never had a problem. Until, that is, I went to the TCS race in New Jersey. Sure enough in practice my car stopped moving. I ws fortunate that another racer had a fully set up gear diff for an M03 and didn't need it because he was running an M05. Well racing season will be here soon and I want to go through the car, but I don't want to mess up the diff. Any suggestions?
What exactly do you mean by a well sorted gear diff?
Oh, okay
An odd effect of the tighter diffs is that RWD cars have been knocked almost completely out of contention. Once the problem of getting the power down in the FWD cars was sorted, that was it. Also, the M06 is an over-engineered, fragile, turd of a car. (M04 still rocks.)
