Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 02-24-2013, 07:04 PM
  #18451
bizkit1's Avatar
Trader Rating: 27 (100%+)
Quick question on the Tamiya titanium hop up screw set. What weight difference is there?? I searched here, but it came back as everything but what I needed to know. Thanks.
George
bizkit1 is offline
Old 02-24-2013, 09:20 PM
  #18452
niznai's Avatar
George
For a touring car I found about 30grams. Perhaps expect around 20 grams for a mini? But why would you want less weight? Lipos are too light anyway, and you'll end up having to add some lead to compensate anyway.
niznai is offline
Old 02-24-2013, 09:56 PM
  #18453
Default Servo for M03
Hi guys. Whats the recommended spec for a servo in a M03 ??
My old Futaba has a few issues, needs to be replaced.
Does the M03 actually need high speed & good torque ??
I have a few to choose from, I just not sure which one to use, from Fut 3003(& Sanwa equivalent) & BlueBird BMS-631 all the way up to hi-speed Ko-Propro
Cheers
1101 is offline
Old 02-24-2013, 10:05 PM
  #18454
R/C Tech Elite Member
monkeyracing's Avatar
Unless you're a top spec racer, get yourself a cheaper servo. I've got Blue Bird (cheap!) and Savox (pricey!) and haven't really noticed a difference. Even just for club racing, cheap servos work in minis. I would suggest metal gears, though.
monkeyracing is offline
Old 02-24-2013, 10:32 PM
  #18455
tony gray's Avatar
Looking for something outside the square a bit? Local r/c parts supplier Bezerk r/c is building up this sucker..
tony gray is offline
Old 02-24-2013, 11:44 PM
  #18456
Cheers
Sorta depends on how long you're going to be around. If you plan on being in the hobby for a spell, get the best servo you can afford. I'm partial to JR and KO servos, and will use a Futaba on occasion. Good servos are cheaper in the long run. The average life of the last 3 JR servos I had to retire was 12+ years. The average price was about $80.
Torque is nice to have, but the ultra speed servos are not necessary. In fact many experienced Mini drivers will use servo speed adjustments as a tuning aid. Often servo speed is slowed down to tame a car that is loose on corner entry.
Get a standard size or a mid profile, metal geared one. Avoid really cheap servos cause they are too expensive. Also, you can notice the difference between a really good servo and a cheapie. Most good servos will center better and are smoother in operation.
I hope you don't have the same experience as a good friend of mine, very stubborn friend, who balked at buying the Jr servo I was pushing. $120 was way too much money. He bought a $30 servo, then another after that failed, then another, when that failed. His third servo has been giving him good service, but it's getting a little stiff. I'm curious if he'll buy a fourth one or go with a Futaba, cause I know he won't give me the satisfaction of buying a JR.
Granpa is offline
Old 02-25-2013, 12:17 AM
  #18457
Ive had 3 KO servos fail on me, for different reasons. Not good, 1 was the most expensive servo Ive ever bought. But I still run a KO in my Xray. I dont think I'll buy another. Perhaps just my bad luck, it happens.
On the other hand, there is nothing worse than a cheap servo that wanders, Ive had a couple of cheapies do that (they went in the bin). Quite embarassing as your car wanders left to right down the straight & getting strange looks from those watching
To be honest ,Im not that keen on using my BlueBird servo ,even though it may be 100% OK. Maybee just save all the hassles of track testing my cheaper servos & buy a Savox ?
Are the Savox 1251's still a issue free servo, in a mini ? Overkill in the mini ? Do the savox metal gears get slop after a while ?
Cheers
1101 is offline
Old 02-25-2013, 12:18 AM
  #18458
niznai's Avatar
Ha. I learnt that lesson too.
After buying a JR heli I started buying JR servos and still have not retired any, 15 years later. Speed and high torque may not help drive the mini but the quality sure saves the servos in a crash. Major crashes in TC racing that have ripped apart my front suspension have left the servo unimpressed. Of course, a good saver is mandatory. Your car may not last 15 years but a good servo will survive several cars as mine demonstrate.
niznai is offline
Old 02-25-2013, 01:38 AM
  #18459
I run the Savox 1251 in my mini, works great. I recommend running a glitch buster style cap though. My son has a bluebird servo in his mini and I have a bluebird servo in my touring car and they work very well.
luda is offline
Old 02-25-2013, 01:56 AM
  #18460
had a good weekend racing here in Holland , we had an international Mini challenge
I was the fastest M05 and my fastest lap was only 0.3 slower then the fastest M03 , unfortuntly my luck in the finals wasnt so good and i finished 7th , started 4th
set up was
Front
springs were Mugen white HARD springs
450 oil 3 hole pistons , and 2mm spacer under the piston in M chassis shocks carbon shock mount shocks in the outer hole
2 degrees camber and 2mm spacer on the steering rods
rear hole on the upright for steering and 2mm spacer under the ball
Rear
Tamiya white springs
550 oil 3 hole pistons and 2mm under the piston in the M chassis shocks
2 degrees of camber , upper hole on the camber link alloy 1.5 degree to in blocks hard rear stabi
we had to use M grippers and grip roll was a nightmare , super glued the front sidewalls of the tyres and i used a Swift body ,
lead in the front bumper and on the opposite side of the motor to balance the car out
if i think of anything else i post it , was still searching for more cornerspeed but the car was really well balanced and tapping dots was no problem as the car wouldnt roll over
sidecarphil1 is offline
Old 02-25-2013, 07:40 AM
  #18461
Like I said. For most people the M03 is the better car. Not knocking the M05, just pointing out that the M03 is better for MOST people. This is especially true for newbies.
I finally have a M05 that works. It took a lot of time and effort and some out of the box thinking to make it that way. Frankly, it's better than my M03s at certain tracks.
Granpa is offline
Old 02-25-2013, 07:43 AM
  #18462
Robert_K's Avatar
Here's a pic of last weekends race. Phil is the Orange car
Regards Robert
Robert_K is offline
Old 02-25-2013, 08:01 AM
  #18463
Core Creations's Avatar
Trader Rating: 110 (100%+)
Thumbs up
I personally find the M05 is smoother and easier to drive fast. I think the M03 is easier to get fast..but at least on carpet the M05 is king in my eyes. I ran the 03 for many years and its proven to be fast and tough. If someone asked just starting out in mini is say go with an 03 because its cheap, easy and plentiful...if they were gonna spend time tweaking and setting up and wanted to race tcs ..id say 05. I remember last time at the Memphis tcs, the 05 was 1/2 a sec a lap faster than very well set up 03s..maybe it was the long wheelbase
Core Creations is offline
Old 02-25-2013, 12:27 PM
  #18464
does anyone know if corsair racing still exists? cant find a website or much info on them
thanks in advance
skiv is offline
Old 02-25-2013, 01:12 PM
  #18465
Skiv: Looks like RCMart and a few others still have some product. Couldn't say if they're still in business though. There are a few of these manufacturers who seem to fly under the radar.
Anyhoo, last week, a friend looked at my M03 and told me that my CVDs were rusty. I thought he was crazy, but when I looked there was a very light coating of surface rust beginning to appear. It's a bit weird because my car never goes anywhere near water and the humidity here especially in winter, is next to nothing. I decided to tear them down, as it was time for a rebuild anyway. Here's what I found. (sorry, no pics)
The interior surfaces had a extremely fine coating of flash rust, as if they'd gotten very slightly damp at some point. The anti-wear grease I built them with...last year maybe...was completely gone. They were as dry as a popcorn fart. Here's the interesting bit: The pins inside the joints were notched on both ends, on opposite sides, to about halfway through. Looks like the forces in the driveline eventually wore a groove into them and it kept getting deeper as it went.
Fortunately, the drive pins that go under the wheel hexes are exactly the same size. (2mm x 10mm) I'm pretty sure these are 3Racing CVDs, btw. I think these units have been in my arsenal since around 2008. Not bad for a cheap part, but they may be on their last rebuild.
Jim
