Team Corally RDX Touring Car
#4696
Yes, its the same as on Simo and Sakke's car..I think the productionversion wil look the same.Here is a better pic..I don't know the partnumber or when it wil be avalible.
Bart
Bart
#4697
Is Corally gonna release the rear left bulkhead that moved the motor in closer to the center of the car, like Toso is running? The car desparately needs to have less weight hanging out on the motor/servo side, and the guard/fan unit will only make things worse in that regard.
#4698
Bart
Bart
Why i remenber that at it was different look when i hold Simo`s RDX in my hand in Rebellion race?
#4699
Jeff
#4700
#4701
Originally Posted by Jeff Brown
The bulkhead was a prototype that we made at Specialized R/C. Chris has the only one because he thought it would be a good idea. We are looking into releasing them but it will require the chassis to be machined. Which the next generation 4.0mm chassis will have added on. The stock chassis however will be another situation. More info to come....
Jeff
Jeff
#4702
Bart
Bart
#4703
Hey I have my RDX with all my parts I have for it for sale..
http://rctech.net/forum/showthread.php?t=93676
#4704
Originally Posted by Bobby J
what about changing the the CVDs to a regular bone , the cvds make all kinds of mechcanical traction , shorting up the wheel base at the rear belt , buy making some bearing holders that move the diff forward , get a shorter belt ..some more things to think about my .02
Jeff
#4705
Originally Posted by 429racer
1. Is there anyway of buying the 24lb/5turn black springs without having to buy the full black spring set? If so what is the part number?
2. How many different pistons are available for the shocks?
3. Do you guys prefer to run a belt tensioner or without?
4. where is a good place to buy parts at a good price?
Thanks guys any info is appreciated! I just got the car (used) today and was going over it briefly making up a parts list.
#4706
Hey Jeff can you answer the number 1 question I had?
Jeff
#4707
I bought the car used (just got it Thursday/yesterday) and it came with the full set of silver and was supposed to come with a full set of black springs, but it came with 6 of the 17lb springs, 2 -12.5 lb springs, 2 - 14.5 springs, 2 - 19lb springs and 2 - 22lb springs. So as you can see I really don't want anymore springs. Also when are the new towers going to be in the states and what is the standard pistons (like in the setup sheets). I want to get all my parts rounded up before I do a total rebuild. First race with the car will probably be Jan. 8th at the home track instead of going to the Novak race (DANG IT).
I appreciate all the help guys and please forgive me for all the questions, I like to know too much!
#4708
The kits came with 0.9mm pistons for a while but since it was a more popular option to run the 1.3mm pistons they were swapped (running change).
Ask any other questions you have. Not a problem.
Jeff
#4709
Trader Rating: 13 (100%+)
Ok....... new towers... i am assuming you mean the lowered ones. They are already available. Just out of stock at the moment. Arriving next week. Also, if you are not running foam tires then i wouldn't worry about it.
Jeff
Jeff
#4710
Jeff
Jeff
