Team Corally RDX Touring Car
#4726
Originally Posted by R Monahan
the job of a team driver is to try new stuff too see if it works. if the team does not try new parts how will the next gen car get better. my car is dialed and I dont have the parts.
well i'm glad your car is dialed but I was asking if the part was going to be made available to the public
if you read my question it asks jeff about the part...it does not say R Monahan please tell me how dialed you are
#4727
Originally Posted by koabich
As another member said. They have to test stuff first before releasing it to the public. What if they just realeased it with out testing and then you bought it and the product didn't work? I am sure you wouldn't be happy. Give them a chankce. One thing I have learned over the years is that Corally is one of the best manufactures at listening to their customers needs.
I asked a simple question to Jeff from corally and I get everybody putting in there two cents.
#4728
hi, what benefits does the short arm do interms of the handling of the car. im running the box setup now for asphalt. i got the kit that comes with one-way in front. i was very impressed with my first outing, i ran mod with it 8x1 checkpoint. i kinda need a little bit more of exit steering coz i couldnt throttle up earlier than usual and i need the car to be more responsive, will the short arms help interms of car reaction? thanksÜ
#4729
Originally Posted by Josh H
so how long do they need to test this part??? its been on chris's car for what a year??? and now ray makes the mod main and he has these parts. so I guess this part works or they wouldn't use it!!!
Besides...... if you think about testing and testing different geometry. There are other things coming so you will not have to worry about trying these. Easier to make little bits than big things to test.
Jeff
#4730
Thank you thats all I need to hear
#4731
Jeff
#4734
Originally Posted by Jeff Brown
Yes, Short arms will help reaction and transition faster as well. Let me know your current setup and we can provide you with some things to try.
Jeff
Jeff
#4736
Originally Posted by Sushi Boy
Try going to 4 deg of caster with flat hinge pins. The front end will bite a little hard in the middle and exit and finish off the corner much better.
-Korey
-Korey
Thanks Korey
#4739
Originally Posted by dawgmeat
Since I sold my FK 05 thinking that the T2 was coming out in Jan. I'm in the market for a new RDX "again" , What new or improved items comes with the updated kit.
First-I have a NIP Carpet spec kit FS in the FS forums!!
OK-some Carpet Spec highlights.
1. 1.3 pistons front and rear.
2. 75% X-Hard arms
3. 3.4mm top deck
4. Multi-position rear body work brace.
5. Chassis designed to fit GP3300 up to IB3800 batteries.
6. Silver spring set (hard springs).
7. Front and rear sway bars
8. Belt tensioner
9. Aluminum 4 deg Caster blocks
10.Dbl diff.
I think thats about it.
Ray
#4740
Helo,
I have a problem: i snapped my diffscrew and the problem is to get the snapped piece out of the outdrive.I tryed to bang it out with a hammer and screwdriver but it dont move I think some people now where im talking about. Is there tread in the outdrive?
can somebody help me plss?
