Old 12-16-2005, 01:16 PM   #4696
Yes, its the same as on Simo and Sakke's car..I think the productionversion wil look the same.Here is a better pic..I don't know the partnumber or when it wil be avalible.
Bart
bart W is offline   Reply With Quote
Old 12-16-2005, 01:50 PM   #4697
Is Corally gonna release the rear left bulkhead that moved the motor in closer to the center of the car, like Toso is running? The car desparately needs to have less weight hanging out on the motor/servo side, and the guard/fan unit will only make things worse in that regard.
Stealth_RT is offline   Reply With Quote
Old 12-16-2005, 02:16 PM   #4698
Bart
You got a picture? I did`t take any, but just looked then that new system
Why i remenber that at it was different look when i hold Simo`s RDX in my hand in Rebellion race?
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Old 12-16-2005, 04:10 PM   #4699
Jeff Brown's Avatar
The bulkhead was a prototype that we made at Specialized R/C. Chris has the only one because he thought it would be a good idea. We are looking into releasing them but it will require the chassis to be machined. Which the next generation 4.0mm chassis will have added on. The stock chassis however will be another situation. More info to come....
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 12-16-2005, 04:43 PM   #4700
koabich's Avatar
Send a message via Yahoo to koabich
Is there a picture of the car with the new bulkhead?
koabich is offline   Reply With Quote
Old 12-16-2005, 04:49 PM   #4701
Jeff
what about changing the the CVDs to a regular bone , the cvds make all kinds of mechcanical traction , shorting up the wheel base at the rear belt , buy making some bearing holders that move the diff forward , get a shorter belt ..some more things to think about my .02
Bobby J is offline   Reply With Quote
Old 12-16-2005, 05:38 PM   #4702
Roger's Avatar
Bart
Wouldn't this break under impact ?
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 12-16-2005, 06:10 PM   #4703
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
Hey I have my RDX with all my parts I have for it for sale..
http://rctech.net/forum/showthread.php?t=93676
Roberto Falcon is offline   Reply With Quote
Old 12-16-2005, 07:15 PM   #4704
Jeff Brown's Avatar
Not quite following you on this......... so you want to go backwards and put dogbones into the car? I do not see that ever happening.
Jeff
Old 12-16-2005, 07:29 PM   #4705
Trader Rating: 17 (100%+)
Originally Posted by 429racer
1. Is there anyway of buying the 24lb/5turn black springs without having to buy the full black spring set? If so what is the part number?
2. How many different pistons are available for the shocks?
3. Do you guys prefer to run a belt tensioner or without?
4. where is a good place to buy parts at a good price?
Thanks guys any info is appreciated! I just got the car (used) today and was going over it briefly making up a parts list.
Hey Jeff can you answer the number 1 question I had?
429racer is offline   Reply With Quote
Old 12-16-2005, 08:04 PM   #4706
Jeff Brown's Avatar
Sure....... at the moment the spring set is the only way to get them. I will see what I can do to have Holland offer all springs seperately. Did you loose them or something? hehe. I just carry 2 sets of each spring set.
Jeff
Old 12-16-2005, 08:50 PM   #4707
I bought the car used (just got it Thursday/yesterday) and it came with the full set of silver and was supposed to come with a full set of black springs, but it came with 6 of the 17lb springs, 2 -12.5 lb springs, 2 - 14.5 springs, 2 - 19lb springs and 2 - 22lb springs. So as you can see I really don't want anymore springs. Also when are the new towers going to be in the states and what is the standard pistons (like in the setup sheets). I want to get all my parts rounded up before I do a total rebuild. First race with the car will probably be Jan. 8th at the home track instead of going to the Novak race (DANG IT).
I appreciate all the help guys and please forgive me for all the questions, I like to know too much!
Old 12-16-2005, 08:59 PM   #4708
Jeff Brown's Avatar
Ok....... new towers... i am assuming you mean the lowered ones. They are already available. Just out of stock at the moment. Arriving next week. Also, if you are not running foam tires then i wouldn't worry about it.
The kits came with 0.9mm pistons for a while but since it was a more popular option to run the 1.3mm pistons they were swapped (running change).
Ask any other questions you have. Not a problem.
Jeff
Old 12-16-2005, 09:04 PM   #4709
raffaelli's Avatar
Jeff
Jeff, that is 1.3's all around?
24ITA
raffaelli is offline   Reply With Quote
Old 12-16-2005, 09:14 PM   #4710
Jeff
I have many questions (LOL), can you brings all the parts and your cars to my house to help me build this car and set it up LOL? I will be running on carpet and I was referring to the lower shock tower. When was the running change made with the pistons? In Cuffs setup for the 2005 Snow Birds it said that he was using stock pitons and in Daygers 3/20/05 Nats setup he was also running stock pistons so I was trying to figure who used what, so on a time line I could possibly make a guess as to which piston they were running. I have the 1.3's in the car right now.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
