Tamiya mini cooper
#4246
I have yet to build my M04M kit, so I may be wrong here... but since the weight is towards the rear in this chassis, wouldn't you want stiffer springs (blue) out back, with softer springs (red) up front? The opposite of the M03 chassis.
#4247
Nope....you need SOFT springs and tyres in the rear of a RWD on-road chassis or you don't get any grip. RWD cars tend to oversteer like mad so you need to tame that with hard front and soft rear.
I know it sounds weird because that isnt how it works with a 2WD buggy, but they compensate by having HUGE tyres in the rear and skinny ones in front.
#4248
Yeah OK, that makes sense. Thanks.
#4249
M04M setup
Hi,
I love the M04M... but I think it will have a hard time against the M03s on asphalt. On carpet they seem to be faster. Hope setup below helps. Dan Garber helped me out a lot on setup. ID = difuser.
FRONT
TypeA to M grip
Medium/firm
50wt 3-hole
3-4mm
REAR
TypeA
Kit foam/soft
kit foam and 50d shaped insert
softest kit foam
blue strip that is super soft
black 1/4" foam (cut to fit)
neon red rear spring
20-30wt 3 hole
3-4 orings
Ball 1/8 turn
3-4mm/level to front
Rear arms below level
FRONT
TypeA to M grip
Medium/firm
50wt 3-hole
3-4mm
REAR
TypeA
Kit foam/soft
softest kit foam
20-30wt 3 hole
3-4 orings
Ball 1/8 turn
#4253
Basics like track condition, surface, temp and grip.
Then I'd say:
Chassis length
Shocks-standard or cva (plastic)or TRF shocks
Springs, oil, pistons, rebound, internal limiters
Ride height and droop
Front and rear toe (rear 1-(1.5 M03R) or 2)
Front knuckles (standard-M03M (New version) or M03R knuckles
Ackerman and bump steer spacing
diff (gear or ball) shims or grease used
tires, inserts and rims (graphic for amount of traction additives)
body
gearing
stablizers
battery
motor
and comments...think that's it...
Then I'd say:
Chassis length
body
gearing
stablizers
battery
motor
#4254
M04M's are great fun when you have them sorted, they can be a handful on more technical layouts but one thing you can put money on is they'll out accelerate any M03 off the start line and out of slow corners.
I have a pretty good setup on it at the moment which makes it very competitive with the M03 brigade, although there are some crazy fast guys with M03's that do have the upper hand.
FRONT
Tire : Tamiya S-Grip Radial
Insert : Shortened Tamiya Hard Touring Car Insert(Yellow)
Shock : TA03 Low Friction Aluminum with 2 hole pistons and 8mm spacer inside the shock
Spring : Tamiya Blue Tuned Touring Car spring(flourescent)
Oil : 50 weight
REAR
Tire : Tamiya 60D Slick
Insert : Shortened Tamiya Soft Touring Car Insert(Red)
Shock : TA03 Low Friction Aluminum with 1 hole pistons and 5mm spacer inside the shock
Spring : Tamiya Red Tuned Touring Car spring(flourescent)
Oil : 30 weight
I have tried this with standard touring car springs but it's a little bouncy and makes the car skip under hard cornering.
As for running 10 minute heats, unfortunately the rear tires do overheat and this causes inconsistency in the handling.
FRONT
Oil : 50 weight
REAR
Oil : 30 weight
#4255
Well I do agree that the rear tires do over heat. but the front tires get almost as hot. The M04's handling seems to get better the longer I run, its the first 5 minutes that its seems to be the most inconsistent.
As for making a setup sheet would you mind making one for the M04 series as well?
Also I like the M04 because it truely does out accelerate the M03 out of the hole and shoot out of the slow corners much faster as long as you finished making all your steering inputs. If I try to a accelerate too soon it will spinout a thats what I'm trying to work on right now.
#4256
Is there an M04 thread on rctech? There's an M04L thread on radiocontrolzone.com, but it's not very active. Plus they seem to be having software upgrade issues. Again.
If not, maybe I should take the bull by the horns and start one...
#4259
I'm not driving one yet, but I've got a Eunos kit waiting patiently on a shelf. I'm going to buy all the necessary hop-ups before I start building.
I've been running an M03 (SWB) for about 9 months now. Crazy fun, thought I'd give RWD a try.
