Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 06-08-2007, 08:14 PM
  #4216
tony gray's Avatar
Thank You! Always nice to get some good feedback...
tony gray is offline
Old 06-08-2007, 09:18 PM
  #4217
NT
NT's Avatar
Trader Rating: 21 (100%+)
Your website is great Tony.
NT is offline
Old 06-08-2007, 10:17 PM
  #4218
tony gray's Avatar
OK..feedback is good unless its from Nathan......
I shall hack your car tomorrow, I promise!
Old 06-08-2007, 10:59 PM
  #4219
NT
NT's Avatar
Can't ya just feel the love?
NT is offline
Old 06-09-2007, 08:46 AM
  #4220
Simon M's Avatar
Gday Tony
Got a m03-r last week which has ceramic grease for the gears would you recommend this or use silicone spray as suggested in your settup guide?
Simon M is offline
Old 06-09-2007, 12:26 PM
  #4221
tbeardmore's Avatar
Originally Posted by Fastforward
Thanks Todd. Do you use the kit grease on the gears or run them dry? What about tire inserts? How about limiting shock travel, I guess we would call that seting droop in our C-dans.
thanks
BBB
Actually I put a "thin" coat of corally diff lube on the inner gears and one extra diff ring inside to tighten the mesh & reduce the diff action. (Give's more "pull" out the corners)
Tire inserts: Right now I'm experimenting with foam insulation tubing for household hot water piping. It adds about 1.2 mm diameter to the tires (Front Only) and seems to reduce side wall flex. Tire's seem to be wearing more evenly too..!
I'm using kit tires for the front and "M's" on the rear.
Use 3 "O" rings on the inside of the shocks w/ 70wt front & 40wt rear.
tbeardmore is offline
Old 06-09-2007, 12:44 PM
  #4222
HobbyPLEX's Avatar
Hey Todd, You forgot to tell him about the 12awg wire on your STOCK ESC.
Tim Ski
HobbyPLEX is offline
Old 06-09-2007, 03:10 PM
  #4223
tony gray's Avatar
Originally Posted by Simon M
Gday Tony
Simon, the set-up in the instructions for the 03R basically suggests that you PACK the diff with the AW grease. Which will obviously have some sort of locking effect to some extent.
I still just use the silicone spray myself on the gear diff as the 'packed' ones loosen after a few runs anyway, and I'd prefer to have my car consistent all the time.
As for the extra rings and other tricks that people use to stiffen the action, well they're illegal where we race so we don't use them at all.
Old 06-09-2007, 04:24 PM
  #4224
Simon M's Avatar
Ive used the AW grease inside the diff,
What im asking about is the outside of the diff which the manual says to use ceramic grease.
Simon M is offline
Old 06-09-2007, 05:06 PM
  #4225
H I
H I's Avatar
Trader Rating: 18 (100%+)
Don't use grease. Silicon spray is fine on out side but I don't use any thing.
Just a warning on AW grease, I use ball diff so I never had problem but some gear diff user told me AW grease leak out and goes into bearing / gear mesh and slow you down on very hot day.
H I is offline
Old 06-10-2007, 01:34 AM
  #4226
Simon M's Avatar
Hiroshi What tires do you recomend for tempe track
Simon M is offline
Old 06-10-2007, 02:49 AM
  #4227
tony gray's Avatar
No ceramic grease on the outer diff bits Simon... Dry or just a HINT of silicone spray. Ceramic grease will slow the bugger down!
Old 06-10-2007, 04:39 AM
  #4228
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
quick question. My cooper slows down dramatically when i turn, it seems like it binds on something, but only when it's on the ground. When i let off the steering coming out of a turn, it's takes off like a rocket. Any way to fix that, has someone else had this problem? Thanks.
-Shaun
HotrodHopkins is offline
Old 06-10-2007, 05:29 AM
  #4229
H I
H I's Avatar
Front : 60D type A with two insert inside(Tamiya hard-53435 on out side, Shimizu sponge on inside)
Rear : Pit shimizu slick soft with HPI mini insert hard
Inserts dont need to be them, sorex mid-B or hard-B work fine.(cut to fit on rear)
H I is offline
Old 06-10-2007, 08:06 AM
  #4230
jino86's Avatar
Hi, new in the mini world and would like to know bout he sport tuned tamiya motor. What is the ampdraw needed for max power of this motor and how much amp is the motor at max batt power?
jino86 is offline
