Tamiya mini cooper
#4261
I have tried to race my Alfa M04 but gave up since I had so much trouble getting it to hook up. It was a whole lot faster on the straights but we have a technical infield that the MO3 just kills in. Plus, you can run the Mo3 tires down to nothing with almost know performance penalty but the m04 is done with a set of tires after one or two runs. But the rear wheel drive is fun for donuts! If I could only get a new Alfa body for it.
#4262
#4263
Don't start aonther thread, I recommend leaving the discussion to this thread
#4264
My recommendation would be to keep the M04 info in this same thread.
I've driven my M04-M Alfa a couple times now (on carpet) and thought it was reasonably well hooked up as built from the box. I think the biggest "problem" with them is TC guys expect 'em to handle like, well, a AWD TC.
I'm also getting set to build a couple M03 RWD conversions per Tony's excellent instructions. The initial report seems to be they handle much like an M04.
#4265
Let's see how the two threads do. If the M04 thread I started ends up being quiet, so be it, we'll let it fade away.
#4273
I looked at the specs for the body and states a wheel base of 208mm and width of 163mm. Then I looked up the spec for the rover mini from Tamiya and its specs read a wheelbase of 210mm and a width of 167mm. My question is with I set my M03r for short wheelbase will that body fit as pictured on the ABC website?
