Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-07-2007, 02:27 AM
  #3496
minimanintaiwan's Avatar
Default diff lock
I tried this diff lock #53200
Yes, great out of corner speed but no braking and you just coast to a stop and no reverse too.. dare I say exhilerating and dangerous at the same time.
Akuhon, does your diff lock permit you to slow down or brake?
minimanintaiwan is offline
Old 03-07-2007, 02:31 AM
  #3497
Originally Posted by Tim K
Yep, that's it - G5.
Have you seen the new 3 Racing blue alloy diff? it has some tricky device in it, looks like it could be lockable ...
Hey Tim, looks very cool indeed. Where's the link? RcMART?
Old 03-07-2007, 03:03 AM
  #3498
[QUOTE=minimanintaiwan]I tried this diff lock #53200
QUOTE]
thats a one way, not a locked diff. A one way only give a locked diff if your on the gas, but you cant break and you wont have motor breaking.
They are build for 4 wd cars not for m03's.
Wouter.Z is offline
Old 03-07-2007, 06:16 AM
  #3499
muahdib4's Avatar
Is that part for M-chassis? Where'd you find it if it is...I need one for my TCS ILLEGAL Mini..the one I won't be racing but like to try out new stuff with.
muahdib4 is offline
Old 03-07-2007, 06:48 AM
  #3500
Don't think its out yet.
http://www.3racing.com.hk/x_products...0Tamiya%20M03M
Old 03-07-2007, 07:38 AM
  #3501
ckbridge's Avatar
Default Spool Parts
The part number for the tree that has the plastic locker is 9005422. I put one in an M03 and it handled kind of squirrelly. In an M03L I think it worked better, more predictable. As noted before, better acceleration, and the tires seem to wear longer. Maybe itís because they arenít spinning as much. The two plastic discs replace the MA1 gears and the MA3 nests between them. Really straight forward and you donít have a bunch of gunk in the diff. If youíre not racing TCS give it a try.
ckbridge is offline
Old 03-07-2007, 07:50 AM
  #3502
Sabastian's Avatar
This isn't exactly locking the diff, but at last weekends TCS race in WI I loaded up my mini ball diff with crazy thick grease. A guy there told me that would help the car accelerate off the corner and not unload the diff as much. His car was fast so I thought i'd try it! My car was nearly undrivable after that! It would pull hard to the right on acceleration and dart to the left if I lifted... needless to say I spent over an hour cleaning all the gunk out of my diff... It seemed like it would work but it seriously changed the handling of the car. I think a totally locked diff would have even worse pull...
Sabastian is offline
Old 03-07-2007, 08:21 AM
  #3503
xrayroooahhhh's Avatar
Default locked diff.....
I shimmed my diff.....various different ways........pretty much created a locked diff with a nicely rusted washer!! Spent countless hours on the suspension...build adjust....build run.....adjust ....then my 9 year old son finishes his Mini......friction dampers....just lowered.....white springs in front....red springs in back......the car is a rocket !!! Handles great right out of the box......I think Tony Gray is right....not much to worry about just drive them and keep smiling!!!! JMO
xrayroooahhhh is offline
Old 03-07-2007, 05:59 PM
  #3504
akuhon's Avatar
Yes, of course .... it can do slow down and brake...
53200 is 1-way ... I use it on my TL-01 to compete against TT-01 ....
Tim K :
I haven;t tried the 3racing diff.... once it's available, I'll give it a try ... and yes, I think it's adjustable for diff lock, as well.
akuhon is offline
Old 03-07-2007, 08:54 PM
  #3505
Trader Rating: 52 (98%+)
Are the Sanyo 3600 stick pack any good? How is that compare to the $80 4200 matched stick pack?
I tried the trinity 4200 zap pack, it has no punch. I use a CE 35 charger.
straightaway is offline
Old 03-07-2007, 09:18 PM
  #3506
tony gray's Avatar
Our experience so far is that 4200's RULE.... Nothing else has the voltage and punch. Even the lipos cant match them.
And you dont need matched ones, any stick pack 42's will do pretty much.
Cant say I've heard anything about the Sanyos at all, but no-one uses them which cant be a good thing!
tony gray is offline
Old 03-08-2007, 01:09 AM
  #3507
People at my track are telling me that their 3600 and 3800 give more punch than the 4200. I have some $80 1.25v 4200 6 cell side by side for my sedan. my old 3800 give more punch but the 4200 does not dump as fast. However, the marbuchi motor does not use that much, I only have to put in 1000 amp?charge after 10 mins of full throttle driving on my Lipo 3200.
How many amps do you charge the 4200 sticks? My pack Peaks at around 4300 and 9.03V. I use a CE GFX turbo 35 at 6 amp and still no punch. I discharge at 30 amp to 0.9v and I only use the pack once each day.
Old 03-08-2007, 08:06 AM
  #3508
Trader Rating: 28 (100%+)
that is surprising...I'm unaware of any 3600 or 3800's that will out perform the recent 4200's
madjack is offline
Old 03-08-2007, 08:15 AM
  #3509
minidriver's Avatar
Originally Posted by Turbonium
that brings to mention.... will the 03M-version suspension be TCS legal on a M04? not that i run the rwd car much at all, just curious in case it comes up.
I may be wrong on this, but I think it was quite successfully tried last year at Nats.
minidriver is offline
Old 03-08-2007, 08:20 AM
  #3510
yep!
madjack is offline
