Tamiya mini cooper
#2746
Originally Posted by H I
What cause gearbox teeth to chip off on mini? I’ve replaced them heaps of times in last few races, I’m talking once every 2-4 meeting. Wasn’t like this before. I’ve checked pinion and diff but no damage at all. Just middle gears and I can’t see any rock or any thing like that inside. I’ve tried –lube gears – no lube –silicon splay all same result. I use gear diff build as per instruction with AW grease inside (not tight at all)
2 - Check motor is mounted properly and pinion is tight.
3 - Check screws holding chassis together. They may be in but loose and not holding chassis tightly together
4 -check all bearings.
#2747
Originally Posted by Z-Mann
a crash is all it takes, so dont crash
Thanks minimanintaiwan. I think you may be spot on about universals. That pin use to come loose all the time. I've been using thred lock on grub screw but pin still comes loose. Any tip on that?
#2748
#2749
[QUOTE=H I]Can't help running into your car. Your mini is like magnet
the reason you run into my car is cause you run on inserts
#2750
#2751
gear snapping
hiya HI!
do you use the regular gear shaft, the hollow metal shaft or carbon shaft for the centre gear?
the reason i ask is that if it's breaking, it could be because the gear shaft is slightly bent or it flexes during hard acceleration, thus causing more pressure on the gear teeth surface and chipping them. roll your gear shaft on a flat surface ( glass tabletop? ) and make sure it isn't bent.
i've been using the hollow metal shaft from the bearing pack. and so far, no gear chips at all.
it'll also help that you use a ball diff instead of a gear diff. a ball diff will allow some slip when your car impacts something. a gear diff has no give at all if both wheels are planted to the ground.
you might also like to check your gearbox halves ( chassis halves ), make sure the holes where the shafts fit into are not elongated due to wear and tear.
i dunt really think lube is gonna help all that much. most racers just skip lubing the gears so that the gears turn more freely. but just in case you really do wanna lube up your gears, use the lightest grease there is, dunt use thick, viscous grease on gears, it causes more pressure and wear.
-alexander
#2753
#2754
we run tamyia rs540 which latley can be advanced, so wit the extra punch from the newer batts the gears would suffer more.i guess u have to be easier on the throttle.i found its more due to a sudden on power impact or running a crazy motor....yeah your right the plastic is crap.i usually boil em for 15min or sometimes coat them with a thin epoxy resin which seems to work, though after time they do need replacing.......... not a huge expense, still mini racing is cheap and much fun
#2755
#2756
i found ball diffs wear out the drive cups to easily plus they cost a lot more and are inconsistant
#2758
mo3 body
tony
i just found some hpi mini 225 mercedes a-class bodies. I was wondering if the'll fit the mo3 and if they'll clear the servo?
thanks
rai
thanks
rai
#2760
The HPI Merc A Class will fit an M03 easily Rai, I didnt list it in our site because it hasnt been available for years..
SWB M04? I dont think so. Not that I've ever seen. At 210mm it'd be even more of a handful!
There used to be a Kai carbon conversion for the M04 but I think that was 225 as well. I think you'd actually have to make one.
Something similar to the HPI M02 conversion that we have on the website would work.
