Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 10-30-2012, 02:14 PM
  #17746
R/C Tech Elite Member
monkeyracing's Avatar
Have any of you tried the 3Racing (3RAC/SHAMU) servo saver in your mini? Tried one last weekend. It's like the worst features of the stock and the heavy duty Tamiya servo savers, all in one package. Lot's of slop and a PITA to assemble.
monkeyracing is offline
Old 10-31-2012, 11:45 AM
  #17747
superspeed's Avatar
Has anyone race with the Alfa Mito body? How's the handling? I realize it's a long wheelbase 239mm, probably most of racers don't run the long wheelbase setup.
superspeed is offline
Old 10-31-2012, 12:16 PM
  #17748
I tried it and did not like it for the M05. Never used it on a M03 cause the BMW or the Cooper 2006 work so well.
Actually gave it to another racer and after a short time it was retired.
Granpa is offline
Old 10-31-2012, 12:30 PM
  #17749
You like the 2006 Cooper? Good, because I just got a few of them cheap. I really like the mwb Swift, but can't justify spending full pop on Tamiya bodies. Looking forward to lwb M03 goodness!
Old 10-31-2012, 12:37 PM
  #17750
axle182's Avatar
Trader Rating: 18 (100%+)
I was surprised running the RX7, I used my M05 in LWB setup. I thought it wouldnt rotate as fast as say either a SWB or MWB. But to my surprise there wasnt any noticable difference. On a tight track, getting the car to rotate quick is really important, so u should enjoy the LWB Jim. I still feel more confident in the rear end grip also.
axle182 is offline
  #17751
SilverShelby's Avatar
I've used the Mito body and it works really well about the same as the 06 cooper
SilverShelby is offline
Old 10-31-2012, 05:48 PM
  #17752
I have raced with the Alfa Romeo Mito body and like it.
rccartips is offline
Old 10-31-2012, 06:38 PM
  #17753
Swampracer's Avatar
Trader Rating: 72 (99%+)
Default Dying rims
Hi guys,
Anyone try dying Tamiya rims a different color other than white (I ordered a bunch of Tamiya #51237 Swift rims).
If so what product did you use?
Thanks Greg G
Swampracer is offline
Old 10-31-2012, 08:26 PM
  #17754
CWILK's Avatar
Originally Posted by Swampracer
Hi guys,
Thanks Greg G
i've dyed proline and aka rims with rit dye in boiling water.
CWILK is offline
Old 10-31-2012, 11:08 PM
  #17755
Trader Rating: 70 (100%+)
The Tamiya wheels will not dye. The plastic is different than the rest of the wheels that you can dye.
PROMODVETTE is offline
Old 11-01-2012, 04:50 AM
  #17756
GreazyFinger's Avatar
have just finished dying some wheels orange today , not Tamiya though , i used a dye used for fabric called ¨Rit¨ works best when its hot , only need a minute or so and its done , longer means darker so its a trial and error thing really , i managed to get the dye onto , HPi mini rims , Cross and Sweep mini rims as well as a set of Proline dish buggy rims , and for an experiment i also dyed the stock diff part from a mini which didnt take the dye as well but its definately a nice shade of orange now ..
the dye is made in the USA so if i could get it here in australia you shouldnt have any issues finding it , i would be very surprised if the swift rims dont take the dye , and as i said hotter is better , i tried to do some with near cold water and it hardly worked at all , also keep the dye its reuseable , i have an old electric kettle which i reheat it in and its working fine a few times over
GreazyFinger is offline
Old 11-01-2012, 08:16 AM
  #17757
Swampracer's Avatar
Default Dye
Thanks guys,
I was just looking to turn the white rims into black. So I'm not worried about shade.
I'm off to the drug store to get some RIT!!
Old 11-01-2012, 08:50 AM
  #17758
It will not work. If you try the boil method the rims will deform. The only way you can get them black is with paint.
Old 11-01-2012, 12:46 PM
  #17759
durtbag's Avatar
Default assy. Tamiya Tires
I've put a fair few sets together over the years with indifferent results, some stay fairly flat, others seem to balloon in the middle. I went back to the build manual today and noticed a footnote stating too "secure inner sponge to tire using synthetic rubber cement". This is something I have never done, I just put the sponge in the tire and then CA the rubber to the wheel.
Does this help keep the tire tread flater? what type of cement does a guy use that does not make the rubber rock hard?
Thanks, Terry
durtbag is offline
Old 11-01-2012, 05:50 PM
  #17760
How much do your race m05 minis chassis weigh with out battery ?
TeamThibault is offline
