Like Tree86Likes
Hpi Pro 4
Old 06-04-2004, 05:08 PM
  #5251
Erik Shauver's Avatar
Erik Shauver is offline
Old 06-04-2004, 05:09 PM
  #5252
Joneser......Interested in both....If I pay freight will you send to Australia......also do you take paypal
Bob
Barger is offline
Old 06-04-2004, 05:11 PM
  #5253
Joneser....email me
[email protected]
Barger is offline
Old 06-04-2004, 07:11 PM
  #5254
Barger....I have emailed you!
Joneser is offline
Old 06-05-2004, 03:54 AM
  #5255
CRASH's Avatar
Trader Rating: 26 (100%+)
Default Spur Gears
Precision Racing Systems, Enough Said. Excellent spur gears and pinions. Use to think RW Spurs were awesome till I ran these, now there is no comparison. PRS all the way!
Later,
CRASH is offline
Old 06-05-2004, 09:56 AM
  #5256
popsracer's Avatar
Default Re: Re: Toe Blocks
Originally posted by rc-zombies
Tower has them instock...
Zombies;
Between Tower and Horrizon I found a full set of the blocks (minus the 0.5 block).
Thanks,
Steven
popsracer is offline
Old 06-05-2004, 10:06 AM
  #5257
rc-zombies's Avatar
Default Re: Re: Re: Toe Blocks
Originally posted by popsracer
Zombies;
Thanks,
Steven
cool.... but I don't think a 0.5 block is available or I may have missed it... where did you see it at?
rc-zombies is offline
Old 06-05-2004, 10:28 AM
  #5258
popsracer's Avatar
Default Re: Re: Re: Re: Toe Blocks
Nope, my mistake. No 0.5 block (would be nice for the front).
I will have the full set sometime next week and this should give me more tuning options to dial the car in for my driving style. Still waiting on the spacer plates that go under the block though. Hopefully soon.
Thanks,
Steven
Old 06-05-2004, 11:30 AM
  #5259
Regional Moderator
Darkseid's Avatar
Default Re: Spur Gears
Later,
If theres no comparison, then those must be some pretty amazing spur gears! I would like to see one of those!
Darkseid is offline
Old 06-05-2004, 06:05 PM
  #5260
lazyboy's Avatar
Default cvd problem
PROBLEM!
i was running 19t today and i rubbed up against a board and i bent s cvd. has anyone had any cvd problem??? if so left me know what you did to keep this from happening...
thanks lazyboy
lazyboy is offline
Old 06-05-2004, 06:13 PM
  #5261
edit
Johnnytc3 is offline
Old 06-05-2004, 06:25 PM
  #5262
JusBox's Avatar
Default Re: cvd problem
Originally posted by lazyboy
PROBLEM!
thanks lazyboy
other than not hitting anything you'll probably have to go with a stainless steel cvd. aluminum is too weak for cvds if you ask me.
JusBox is offline
Old 06-05-2004, 06:53 PM
  #5263
RCTech Member #2
TSR6's Avatar
preston, I bent tweaked a CVD - I still ran it though, it wasnt to bad.
TSR6 is offline
Old 06-05-2004, 06:54 PM
  #5264
HuDy WiNnEr's Avatar
Default Bent CVD
Hey, i was running modified out here in San Anotnio and i have been racing for about four or five year and am a aldus design team driver(just needed to provide info. , this is my first post) i have probably had not to many hard hits and last weekend i smaked the wall and that one hit caused it to bend so you arent the only one.
p.s. the tc3's cvd's are the exact same thing if you need a quick replacement:
HuDy WiNnEr is offline
Old 06-05-2004, 07:28 PM
  #5265
popsracer's Avatar
Default Re: Re: cvd problem
Actually if it's not bent too bad you should be able to straighten it. I do it all the time on my Nitro cars with Steel CVD's and they get bent pretty good in a major front hit. I chuck the bone in my Drill Press then tap the opposite side with a Rubber Mallet.
Aluminum CVD's usually wallow out the pin holes in the bones pretty quickly compared to their Steel counterparts. This is the tradeoff if you want less rotating mass in your drive-train.
