Like Tree86Likes
Hpi Pro 4
Old 09-06-2005, 09:44 PM
  #12751
Essnowyt's Avatar
Originally Posted by no1uno
If you do the math you can't get to 2.5 to 1 with a 39 tooth ring gear the only formula that works is 16/40 that is a tc3 gear set is.The only way to get it with 39 tooth ring gear is a 15.6 pinion.
I’m not gonna argue with you on the math. You can try to explain it to AE. Look at page 22 of a TC3/4 manual. AE has the final drive listed as 2.5:1. So if you are putting TC3/4 gear in your Pro4 change both front and rear.
Snowy.
Essnowyt is offline
Old 09-07-2005, 05:29 AM
  #12752
Paladin's Avatar
I know we all love the Pro4 here, but heres my question.
I assume that certain cars are perceived as 1st class cars, and then tehre are the next level down, and so on...
The Pro4 if not the best, then one of the best 1/10 EP cars.
Which cars are at the top with the Pro4, and which would fall in the classes below?
I hope this makes sense?
Paladin is offline
Old 09-07-2005, 10:07 AM
  #12753
Oasis's Avatar
Trader Rating: 38 (100%+)
I would think that any TC over the price of $250 would be in the same "class" as the Pro4,05FK,RDX,415MXS..etc
Oasis is offline
Old 09-07-2005, 10:47 AM
  #12754
Entropy's Avatar
I have a fan!
Entropy is offline
Old 09-07-2005, 03:53 PM
  #12755
TheCoolCanFanMan's Avatar
Hi
To all that have that have kindly purchased Cool-Can-Fan's for their cars. We now have a NEW L K website
Cheers Malc (The-Cool-Can-Fan-Man)
www.coolcanfan.com
TheCoolCanFanMan is offline
Old 09-07-2005, 03:57 PM
  #12756
Originally Posted by Entropy
I have a fan!
Sorry about that ... I changed it.
John Warner is offline
Old 09-07-2005, 04:03 PM
  #12757
rc-zombies's Avatar
Originally Posted by Trakside Trucke
Hi
www.coolcanfan.com
very nice...I've got several fans sitting around..
what size fans do they accept.. for the Pro4 of course..
rc-zombies is offline
Old 09-08-2005, 04:24 PM
  #12758
Does anybody make aluminum bulkheads for the Pro4?
Old 09-08-2005, 04:26 PM
  #12759
rc-zombies's Avatar
unfortunately no...
I've asked HPI if there is any plans for aluminum bulkhead like the evo's and SD's... they have no plans to do so...
Old 09-08-2005, 04:43 PM
  #12760
Well hopefully somebody like shooters or another company will step up!
Old 09-08-2005, 04:59 PM
  #12761
Trader Rating: 14 (100%+)
John:
Get Diggity to make some.
TimXLB is offline
Old 09-08-2005, 07:54 PM
  #12762
Hey Tim, that's a great idea! Why didn't I think of that? Must be why you get paid the BIG bucks!! Thanks for the help!!!!
Old 09-08-2005, 08:09 PM
  #12763
floodo1's Avatar
why would you want AL bulkheads? any benefits will be outweighed by the substantial weight increase (at least if you keep it fully sealed, and if you dont keep it sealed you're REALLY sacrificing and even then i doubt you could get the weigh equally light as crp)
the dhi 05' setup seems to be good for one-way tracks (flowey and non super sharp corners). its one of the only setups i've seen to use anti-dive in the front which to me reinforces that it was made for higher speed tracks (anti-dive to prevent too much front weight xfer). seems to be made to have fast cornering speeds.
for small tracks i dont think its the ticket because of the one-way. and if you swap out the one-way you're gonna change the handlig characteristic so much that you'd prolly do better to find a spool setup as a baseline instead of this one.
floodo1 is offline
Old 09-08-2005, 08:14 PM
  #12764
ChadCapece's Avatar
Come on floodo1, you of all people should know, it's all about the bling bling. And possibly more freespin from the precise bearings alignment.
ChadCapece is offline
Old 09-08-2005, 08:57 PM
  #12765
josh69162's Avatar
Ahhh... more freespin! As if 8 million seconds isn't enough! I know I have a lot of freespin, but I'm curious. What things would I be able to lighten in the drivetrain... I've got blue tc3 bones up front, composite tc3 bones in back, aluminum input shafts, delrin rear cups, front one way... Is there anything I can lighten to take advantage of my drivetrain?
-Josh
josh69162 is offline
