Hpi Pro 4
#5236
but mybe if your using a high power mod motor (12 or 10t say) maybe the CA will just get ripped off.
if you get what i mean
#5237
Mossie, the stock gold springs are 19lb and the silver ones are 16.9lb.
#5238
Toe Blocks
Guys;
OK OK already, I give up. Can't win agains't an Army
My point was that 2.5-3.0 degrees per side has always been excessive in any of my cars, especially Electric Cars.
Now, does anyone know who has the option toe blocks (less than 2.5) the in stock at the moment (preferably in the USA)?
Thanks,
Steven
Thanks,
Steven
#5239
Re: Toe Blocks
Originally posted by popsracer
Guys;
Now, does anyone know who has the option toe blocks in stock at the moment (preferably in the USA)?
Thanks,
Steven
Guys;
Thanks,
Steven
#5240
Originally posted by VenomWorldOrder
for anyone that wants to make a spool but has no metal lathe is there a easier way to make one?
is it possible to just fill a oneway with CA glue and do it like this??
#5241
#5243
spir and ratio
hey folks!!!
does anydoby know which spurs fit this car????
thanks!
thanks!
#5245
Re: spir and ratio
Originally posted by SalvadoriRacing
hey folks!!!
thanks!
hey folks!!!
thanks!
Xenon spur gears work best..but others like
Robinson and Kimbrough std. spurs should fit fine
as long as there are 4 mounting holes ...
#5246
Trader Rating: 32 (100%+)
The biggest spur you can fit with the stock chassis is a 102 tooth 64 pitch....with a thicker chassis you can fit a 104 tooth. The problem with the larger spur is that it hangs out the bottom of the chassis. Hope this helps you....Im not sure on 48 pitch as I have not run that on the car.
Edit....and any normal spur gear will fit Kimbrough, RW, Trinity or HPI they all fit with out issue.
#5247
Hey Pro 4 guys......I have 2 things that you may be interested in. I have a stock chassis that has never been used and a built but never used one way. Chassis was prepped by the guy I bought the unused kit from. I will let these go for 50.00 shipped (total for both). I will sell individually for 30.00 each (shipped).
#5248
Regional Moderator
Re: spir and ratio
hey folks!!!
thanks!
hey folks!!!
thanks!
-strongest, lightest, thinnest, truest spinning=best!
#5249
any suggestion for 48 pitch gears???? what are the biggest spur and the smaller spur that fit the car???
