Xray T3 2012
#721
slop in turnbuckles
Hi,
Ive just bought a t3 12 and i notice that straight out the box there is a fare amount of slop in all the turnbuckles! Is it good to have a bit of slop or are there different ball joints or cups from another make of car that can be used to get rid of this??
#722
hi lads,
i run the "12" tonight, car felt great with minor changes only in stock "blinky mode tho" but still handles good only thing is xray needs to sort out supplying 50mm drive shafts in the kit for the rear.i trimmed the swing shaft protector thinking it would help which it did but still was not getting the travel i needed in the rear arms.it was stepping out in the rear then i put 50mm drive shaft in and problem fix rear not stepping out. i could only accomplish 3_4mm travel with 3deg toe and with 2deg camber with trimmed protector.
#723
Hi guys I am getting a T3 12 and i was wondering what is a good motor to get for it.
#725
just a stock motor. I want a 17.5t
#727
ok thanks
#729
ok thanks. what are the good speed passions i heard that they are good.
#731
17.5
Speed Passion... That's a good one! You want advice from this guy?
Transplantlife speaking!
http://www.beamish.com/files/VoiceMailLeftBySeller.mp3
#732
Ok and what is the track called is it carpet?
#734
what is the track called that you go to.
#735
