Like Tree1Likes
Xray T3 2012
Old 02-14-2012, 12:58 PM
  #1471
wwddww34's Avatar
Trader Rating: 9 (91%+)
Hey all you Xray T3 '12 racers, have you signed up to race your T3 at the 2012 ROAR Carpet Nationals coming up on March 16? Rumor has it that the T3 '12 is going to dominate the modified sedan A-Main. Hurry up and register before time runs out! Click here to get signed up.
Click
HERE to see a countdown to the 2012 ROAR Carpet Nationals
wwddww34 is offline
Old 02-14-2012, 01:25 PM
  #1472
locked's Avatar
http://www.roarracing.com/national_r....php?raceid=20
So far there is 1 entry for mod TC. Is the one entry an XRAY? If so, I guess XRAY really will "dominate" mod sedan
locked is offline
Old 02-15-2012, 10:06 AM
  #1473
Ariel Reds's Avatar
hello there, i just wonder if i want to change the diff oil, did i need to change to the o-ring and the gasket?
Ariel Reds is offline
Old 02-15-2012, 10:12 AM
  #1474
locked's Avatar
You probably won't need to change the gasket, but the o-ring tends to expand, so you will want to replace that or I've heard some guys just run a bead of green slime around that o-ring area and omit the o-ring entirely. I've seen a couple of my friends cut a small section out of the o-ring to re-fit it. Personally, I'd just put in a new o-ring.
locked is offline
Old 02-15-2012, 10:18 AM
  #1475
Ariel Reds's Avatar
ow okay thanks
one more, is it okay to run gear diff at front? known that T3 had much more steering but if the present of the diff in front will make any difference?
Old 02-15-2012, 11:33 AM
  #1476
Default Top retainers
Originally Posted by HarryLeach
I'm not the first person to discover that they work. I can't remember who posted it up in the T3'11 thread, but I picked up a set immediately after hearing about it, and I've run and been happy with them ever since. For me, it's one less thing to fiddle with, leaving me more time for more important adjustments to try.
Hi, how do the top retainers fit on to the std driveshaft axles, are they not the wrong shape, what holds them in place?
Matt W is offline
Old 02-15-2012, 12:09 PM
  #1477
303slowdown's Avatar
Trader Rating: 24 (100%+)
I recently got the vbc t32f chassis and clamps through crc and am very happy with the quality and performance of the kit. I would recomend it if your in the market for something a little different.
303slowdown is offline
Old 02-15-2012, 12:34 PM
  #1478
M-Technic's Avatar
Trader Rating: 15 (100%+)
I think this is why I assumed they don't work also. But even though Xray only uses a crescent shaped axle, it should work as HarryLeach says.
M-Technic is offline
Old 02-15-2012, 12:48 PM
  #1479
HarryLeach's Avatar
It's hard to see in pictures of the TOP retainer, but they have a decent lip on one side that keeps them from sliding over the whole joint. Once installed in the bearings and hubs, there's no wobble, some slight inboard/outboard play, and when installed the cross pin is never uncovered.
Is it perfect? No, but it does work very well.
HarryLeach is offline
Old 02-15-2012, 01:25 PM
  #1480
RC MARKET's Avatar
A+ New Option Parts for T3'11 & 12
Attached Thumbnails Xray T3 2012-ap-21002.jpg   Xray T3 2012-ap-21801.jpg   Xray T3 2012-ap-21801-1.jpg
RC MARKET is offline
Old 02-15-2012, 05:32 PM
  #1481
smilekt's Avatar
cant wait to receive my T3! finally i join team xray
Welcome Champ ... nice to hear ...
smilekt is offline
Old 02-15-2012, 05:33 PM
  #1482
smilekt's Avatar
ow okay thanks
bump for top driver question ..
smilekt is offline
Old 02-16-2012, 01:16 AM
  #1483
blade072's Avatar
Trader Rating: 98 (100%+)
+1 ive been using the top retainers for ages....never had a failure since...and it eliminates the use of a grub screw....no more chewed out steering blocks for me....
blade072 is offline
Old 02-16-2012, 07:04 AM
  #1484
M-Technic's Avatar
ow okay thanks
I use a gear diff in the front, filled with cleaning putty (almost locked). I think it makes the car easier to drive for modified on outdoor asphalt. It has more initial steering.
Old 02-16-2012, 04:06 PM
  #1485
Ariel Reds's Avatar
okay thanks!
first run yesterday, after couple minutes, i broke my rear upright and the CVD just gone i had problem with the pin and the upright seem not very tough as I not accident while i test it
