Like Tree1Likes
Xray T3 2012
Old 11-27-2011, 04:29 PM
  #736
TfnG's Avatar
Trader Rating: 27 (100%+)
im pretty happy with my Novak Ballistic in 17.5 blinky class. ive had good luck on and off road with that motor...
TfnG is offline
Old 11-27-2011, 05:00 PM
  #737
theatriks's Avatar
+1 on the corally!
theatriks is offline
Old 11-27-2011, 06:55 PM
  #738
Davin's Avatar
Trader Rating: 43 (98%+)
Can anyone confirm if this multidiff will work in the 2012?
http://www.nexusracing.com/product_i...oducts_id=3643
Thanks in advance
Davin is offline
Old 11-27-2011, 07:26 PM
  #739
M-Technic's Avatar
Trader Rating: 15 (100%+)
Thanks in advance
Yes it will work.
M-Technic is offline
Old 11-27-2011, 07:45 PM
  #740
Davin's Avatar
Originally Posted by M-Technic
Yes it will work.
Thank you sir
Davin is offline
Old 11-27-2011, 09:35 PM
  #741
mikel33's Avatar
Trader Rating: 2 (75%+)
Originally Posted by rcguy48
what is the track called that you go to.
Hi RCGuy. Our Track is The Track @ Harbor Hobbies. We are up in Winthrop Harbor (almost Wisconsin!). Website is Harbor-Hobby.net. The carpet is 90-ish by 36. We run sedan (17.5 blinky), vta, mini, 1/12 etc. I don't want to hi-jack this thread, so if you have any questions send me a pm or contact Eric at the shop.
michael.
mikel33 is offline
Old 11-28-2011, 11:33 AM
  #742
sham55's Avatar
Originally Posted by bucketboy
Yep, me! tried every oil thickness you can think of, none are thick enough, use cleaning putty to bog down the gears, its not got as much pull out of the corners as a spool but a little easier on the drive train and easier to drive, you need to try it for yourself to know if you like it or not.
Bb
thanks for the tips bro
sham55 is offline
Old 11-28-2011, 02:06 PM
  #743
Default turnbuckles
Hi,
Ive just bought a t3 12 and i notice that straight out the box there is a fare amount of slop in all the turnbuckles! Is it good to have a bit of slop or are there different ball joints or cups from another make of car that can be used to get rid of this??
Matt W is offline
Old 11-28-2011, 02:24 PM
  #744
Skiddins's Avatar
Originally Posted by Matt W
Hi,
You need a little bit of slop in the joints to help the steering to center.
If you want to remove some of the slop, try wrapping some plumbers PTFE tape around the ball joint then snap the rod end onto it.
Helped on mine.
Skiddins
Skiddins is offline
Old 11-28-2011, 02:31 PM
  #745
dr_hfuhuhurr's Avatar
Trader Rating: 93 (100%+)
Hi,
No slop anywhere in my new T3-12. Not sure what could have happened.
dr_hfuhuhurr is offline
Old 11-28-2011, 02:38 PM
  #746
Robertcooper88's Avatar
where can I get a Corally Pro Red 17.5 motor?
Originally Posted by Mb3195
For stock, only one motor to get (if you can get one) corally pro red. Miles miles faster than anything else out there!!
Robertcooper88 is offline
Old 11-28-2011, 02:45 PM
  #747
Trader Rating: 38 (95%+)
for the front do you use 50 or 52 mm ecs units, about to order the shafts so just want to make sure
zaraz is offline
Old 11-28-2011, 03:17 PM
  #748
http://www.corally.co.uk/motors/82-p...-series-motors
In blinky nothing can live with a pro red
bucketboy is offline
Old 11-28-2011, 03:19 PM
  #749
Hi,
Got no slop in any of the ball cups but you can put a soft 3mm o ring over the ball, then the cap will be a snug fit
Bb
Old 11-28-2011, 07:14 PM
  #750
Johnny Wishbone's Avatar
Hi,
If you have slight slop and a plastic bag fix is too thick, try saran wrap, its quite a bit thinner mil spec and you can double it if you have to. It also kind of cuts itself so you don't have to trim it after you snap the ball cup back on.
Johnny Wishbone is offline
