Ask Aaron Waldron
#2778
Tough Kevlar gears are good! Who cares if they're noisy.
binary - I'm a confused 20 year old who gets into trouble all the time...you're asking the wrong person, LOL.
Casper - I haven't heard anything. It's an electric car...
#2780
#2781
The meaning of life is 42? That's more confusing than searching for the answer...
Casper - I'll be at the Shootout, for sure!
#2782
Aaron, Can you try to find out when the xxx-cr will ship out for us. thanks
#2783
Losi generally ships them so that they arrive on both coasts on the same day. From what I've heard, shipping started this Monday, so people have been speculating Thursday on the shelves.
#2784
Is there a simple method of removing glued tires from a set of rims, or is it standard practice for those who race often to keep buying new rims along with their tires?
#2787
for the tire removal...cut the tires off till only the glued parts of rubber from the tire are sticking to the rim (so cut off everything except for the sidewalls..) and soak them in acetone..most people just soak them in acetone, and the rubber should come right off with a slight pull..like killer said...also depends on what glue was used...if u used really strong glue..it will be alot harder to take off unlike the glue i use..and i get it from the 99 cent store. ROFL! the glue works great though for only a buck!
#2788
rgb - Looks like killer89 got that taken care of.
I've heard of the oven trick...personally, I've only ever used acetone to re-use old rims. However, it is (or should be) standard practice to replace rims that are tweaked, bent, or otherwise beat up.
#2790
Anyone know if a BK2 front shock tower will fit on an XXX-T MF2? I was thinking of installing a BK2 body but it appears I need the BK2 shock tower and some rear posts.
