Tamiya TT02 Thread >
Tamiya TT02 Thread
Like Tree1135Likes
Tamiya TT02 Thread
    Hide Wikipost
Old 01-14-2021, 03:44 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Tamiya TT02 Thread
Last edit by: pparrett
TT02 Wiki - Post your setups, upgrades and home grown ideas here for us to read...
TT02 vs the TT-01
http://www.thercracer.com/2013/01/ta...irst-pics.html
New flat chassis layout - Easier to run LiPOs vs the cutouts in the TT-01s
Revised suspension geometry
Support for std spur gears
MODELS ----------------------------------------------------
Changes that follow are in comparison to the basic kit.
TT02 - Base Kit. Friction Dampers.
TT02D - Drift: Drift Tires, Hardened A-Parts, Oil Shocks
TT02R - Race: Rear Alu 3* Toe In Hubs, Alu Propshaft + Cups, CVA oil Dampers
TT02RR - Race+: TT02R + Adjustable Upper Arms, Oil Filled Diffs, Hardened Blue Chassis
TT02S - Type S: TRF416 arms, FRP shock towers, bearings,
TT02SR - TypeS Race: TT02S + Double cardan front drive shafts, rear lightweight universals, Rear sealed oil differential, front spool
TT02B - Buggy. Offroad: CVA Shocks, Double Wishbone long suspension
HOP UPS ----------------------------------------------------
Bearings:
#54476 Ball Bearing Set TT02: 8x 1050, 4x 1280, 4x 1150
Propshaft:
#54501 Alum Propeller Shaft TT02
#54502 Alum Propeller Joint TT02
Tip:
Put a 3mm piece of well greased silicone hose between the dog bone and the shaft of each wheel to reduce slop.
Motor Mount and Gearing:
#54558 TT02 Aluminum Motor Mount
#54500 High Speed Gear Set
#54875 Oil Gear Differential
Steering:
#54550 Low Friction Step Screws
- Full Upgrade Kit -
#54752 Steering Upgrade Kit, Includes all below.
- Individual Parts -
#54574 Aluminum Steering Set
#54575 Aluminum Steering Bridge
#54799 Hi-Torque Servo Saver or #51000 Servo Saver Black
#54248 Aluminum Turnbuckles 3x23
#50797 5mm Short Adjustable Turnbuckle End
Dog Bones to Universal Joints:
- Standard Steel -
#53792 Universal Shaft Assembly (steel), NOTE: Must also use item 54477 on the TT-02
#54477 Gearbox Joint for Universal Shaft (steel) (2pieces)
- Lightweight -
#53506 Blue Aluminum 39mm Swing Shaft
#53499 Wheel axle for assembly universal
#53681 Titanium wheel axle for assemblu universal (but this is very expensive)
#53500 cross joints for universal
#54477 Gearbox Joint for Universal Shaft (2pieces)
Tip: Run steel in the front, Alu is okay for the rear but the front takes a lot of wear and impact from crashes
Shock Options:
#54753 Super-mini CVA Oil Shocks, comes with med black springs
#42102 TRF 55mm Shocks
Chassis:
#54639 Carbon Damper Stay Front
#54640 Carbon Damper Stay Rear
#47339 Hard Lower Deck Blue
#47340 Hard Lower Deck White
#54926 Hard Lower Deck Black
#54733 Aluminum Rear Uprights, Gives 3* rear toe in for extra stability
#54549 Aluminum Rear Uprights, 2.5* Rear Toe In
#58584 Hardened A-Parts, Uprights, Hub Carriers, Diff Covers, etc
SUGGESTED BASE SETUPS ----------------------------------
Bashing:
Build to the kit instructions and have fun!
Asphalt Parking Lot Racing:
Front Diff: 300k-500k (or Tamiya #42247 Gear differential putty)
Rear Diff: 3K oil in the rear diff for low / medium grip, 5k oil in the rear for medium / high grip
Carpet Indoor Racing:
Rear Diff: 7k -10k in the rear diff for very high grip carpet.
ADDITIONAL RESOURCES -------------------------------------
TT02 Build and Review here
http://www.thercracer.com/2013/05/ta...nd-review.html
TT02 Tuning and Mods Guide
http://www.thercracer.com/2014/08/ta...-and-tips.html
https://www.rcdriver.com/take-the-versatile-tamiya-tt-02-chassis-to-the-next-level/
Gearing for 17.5t Blinky
http://www.thercracer.com/2013/07/ho...inky-with.html
Print Wikipost
Old 07-02-2020, 02:45 PM
  #2566
IndyRC_Racer's Avatar
That custom pin retention ring is a great idea. FYI: Acetone can break down super glue. Just don't use acetone on Tamiya ABS plastic (such as the wheels) unless you want to totally dissolve the plastic. Just be careful not to let it soak into your skin.
IndyRC_Racer is offline
Old 07-04-2020, 12:51 PM
  #2567
FYI the new tt02s and sr steering is out of box a good choice and I will stick to the new one.
Sukram is offline
Old 07-13-2020, 09:05 AM
  #2568
Originally Posted by Kremzeek
I just want the body.
me too - I remember when those were the real thing.
sethwas is offline
Old 07-25-2020, 08:51 PM
  #2569
Trader Rating: 29 (100%+)
Bought diff lock number 54649 and it's not compatible with my tt02rr diff. Did I buy the wrong part? Drive cup to big to go into the diff lock hub. Love wasting money if this is not it lol
Gyr0 is offline
Old 07-25-2020, 10:14 PM
  #2570
Part is correct, but you will need Standard TT-02 Diff housing (Tamiya 51331) to get the spool fit your RR.
JJ100179 is offline
Old 07-26-2020, 07:46 PM
  #2571
https://www.tqrcracing.com/shop/prod...asp?p_id=15672
Has anyone used these diff joints with the tamiya locker? And would these work with univervals if i end up going that route?
Gyr0 is offline
Old 07-26-2020, 09:07 PM
  #2572
fyrstormer's Avatar
The custom pin-retention rings look nice but are ultimately unnecessary. Degrease the CVD components (assuming they were lubricated in the first place), then lock the set-screw in place with a drop of Red Loctite. Wait a day before re-oiling it. It will never come apart again, unless you heat the CVD with a lighter to melt the Loctite. This procedure works great on the CVDs on my HPI Bullet, which has the same size CVD joints but they are much more highly-stressed by driving monster truck tires. I've never had one come apart by accident, but I've always been able to disassemble them to replace broken drive pins when necessary.
fyrstormer is offline
Old 07-26-2020, 10:23 PM
  #2573
fyrstormer's Avatar
What is the difference between the TT-02SR and the TT-02S? Also, what is the difference between the TT-02SR and the TT-02R? I assume combining the letters from the -R and the -S means Tamiya also combined the improvements from both versions of the chassis, but I'd like to know for certain.
Old 07-27-2020, 02:03 PM
  #2574
Raman's Avatar
Trader Rating: 94 (100%+)
The TT02, TT02D, TT02R, RR use standard suspension arms, which are upper and lower A arms. The RR adds a few extra hop ups to the R
The TT02S and TT02SR use the same arms as Tamiya TC chassis. They do not have an upper arm. The SR adds a few extra hop ups to the S.
Raman is offline
Old 07-29-2020, 09:04 PM
  #2575
I put this kit (base TT02 with Impreza body) together a while ago and ran it a couple times in the basement with a cheap servo that I finally swapped out. I always had weird steering issues, but even with a newer Savox in there it still couldn't center properly. It centered fine after turning left, but after turning right it would go past center. I messed with tightness in all steering linkage, which is nearly impossible to remove anywhere near all the stiction in the steering. I ended up pulling the factory servo saver and popped in a high torque servo saver and it centers as it should now. My guess is the factory servo saver is too weak.... The steering friction really has me eyeing the aluminum upgrade.
Figured I'd post this in case it can help someone else thinking they've blown a servo, but just have a weak servo saver
tkvtec is offline
Old 07-30-2020, 01:01 AM
  #2576
Questions?? What Motor wouldn’t overheat
Hello, I’m still trying to learn a lot about rc rn and I have this Tamiya TB-01 and I really want it to go from this brushed beginner car to something must faster and better. Although its AWD and I have heard you cant just throw any motor in there as it may overheat so please suggestions on what to put in it to make it hella sick.
Jds0007 is offline
Old 08-01-2020, 11:39 PM
  #2577
https://www.tamiyausa.com/shop/spare...-tt02-g-parts/
Anyone got a spare set laying around by chance they can sell? Seems to be out of stock pretty much everywhere stateside
Gyr0 is offline
Old 08-04-2020, 06:04 AM
  #2578
Minty Fresh's Avatar
I have an SR and I'm curious if the upper deck (chassis brace) from the TT-01E will fit. Since those two holes on either diff cover are open on the SR, was hoping it would work/line up. Anyone tried it?
EDIT - Never mind, just found someone else ion the thread that asked the same question, seems it's a tad too short. Bummer.
Minty Fresh is offline
Old 08-12-2020, 04:19 PM
  #2579
chef88's Avatar
Trader Rating: 75 (100%+)
(54875) may be the part #. 51331 Is a Land Cruiser.
chef88 is offline
Old 08-12-2020, 08:14 PM
  #2580
Raman's Avatar
Overheating happens when the car is over geared, with respect to motor.
Generally speaking, you would gear the following motors as follows:
fdr = final drive ratio
17.5 around 3.8-4.0 fdr
13.5 around 4.5
10.5 around 5.0
8.5 around 6.0
4.5 around 7.0
final drive ratio is spur gear divided by pinion gear x internal ratio..
so a TT02 has an internal ratio of 2.6, so if you run a 86 spur and 25 pinion, you’re looking at
86/25 = 3.44; x 2.6, 8.944.. so you could run a very hot motor with this gearing and it would not over heat.
as a precaution it is recommended that you check the temp regardless after every run.
Now I personally don’t recommend any motor faster than a 13.5 in the TT02.
Raman is offline
