Kyosho VoneR Thread >
Kyosho VoneR Thread
Like Tree1Likes
Kyosho VoneR Thread
Old 10-15-2003, 06:36 PM
  #9511
AMGRacer's Avatar
Originally posted by Manticore
i doubt about the rear down force of this body.
The wing you see is the "style wing". A proper full sized wing is included as well and I use this one. It is not too bad body, lacking downforce generally but is quick in a straight line.
AMGRacer is offline
Old 10-15-2003, 06:38 PM
  #9512
AMGRacer's Avatar
Originally posted by esham
Oppsss... when through HK forum. Yup..dtm did posted pictures and suggestion. Can't believe it - 3racing !!?
Pretty bad quality from 3 racing right Esham. I think they assume you will also use their chassis plate with the battery holder already included.
How you finding your MTX3 vs your EVO nowday?
AMGRacer is offline
Old 10-15-2003, 07:26 PM
  #9513
mckrooz's Avatar
Originally posted by Taylor-Racing
Maybe.
Remember that when using the conversion kit the only assembly you really keep is the rear bulkheads together with the suspension bits etc. that are attached to it. Pretty much everything in front of the engine is new/different.
Will the rear end bolt onto a V-One XXX chassis?
The Reflex gears are different, I believe.
Yes, it should work. I'm running a Reflex on a V-One chassis with no problems. The only thing you can't use is the 2 speed. They have different shafts.
mckrooz is offline
Old 10-15-2003, 07:53 PM
  #9514
esham's Avatar
Yup.. I believe they expect selling the chasis and the battery holder. That is business trick! But i love more on my shimo chasis
AMG, So much thing happen on the weekend, golf match, job outstation etc. I couldn't play much with those babies. Local weather - raining Almost want to get Mini-Z to play indoors I can't really get 100% comfortable with my MTX-3 and EVO yet compare with my existing V1RR. I believe i need more time with them. Still learning to get balance between my driving style and car tweak / setup Meanwhile upgrade my Evo and MTX3 with option parts stuff..
esham is offline
Old 10-15-2003, 08:21 PM
  #9515
coldeye's Avatar
Default Kyosho V1RR fuel tanks
Has anyone had any problems with thier v1rr fuel tanks leaking at the seams? I am having a problem, or bad luck, or both. My original one split at the seam and leaked on me during a race. I took this as a one time. I installed a brand new replacement and found it also leaked. Any replacement or quick fixes besides a soldering iron will be helpfull.
coldeye is offline
Old 10-15-2003, 08:24 PM
  #9516
AMGRacer's Avatar
Default Re: Kyosho V1RR fuel tanks
You mean at the plastic seams? Or from the foam packing on the lid?
I have never had a problem with the plastic parts. I did have one tank spring a leak from the foam insert getting crushed and no longer sealing properly. Easily fixed with a $5 part.
AMGRacer is offline
Old 10-15-2003, 08:32 PM
  #9517
coldeye's Avatar
It was definetly the seam on the first tank. Then it appeared the fuel pick up nipple was leaking on the new tank. Also can too short a pressure line cause excessive pressure in the fuel cell during operation forcing air leaks in areas discribed on my fuel cells or in the cap seal.
coldeye is offline
Old 10-15-2003, 10:49 PM
  #9518
Manticore's Avatar
use a soldering iron and carefully seal the leaking part of the seam.
Manticore is offline
Old 10-15-2003, 10:55 PM
  #9519
alana07's Avatar
Trader Rating: 53 (100%+)
any url for the HK forum?
alana07 is offline
Old 10-16-2003, 12:29 AM
  #9520
Default Clutch bell?
Anybody got a (spare) 3D Clutch Bell they can sell me? I gave it to my dad to get the gears off so I could change them to larger ones and I ended up with a bent clutch bell ! I've tried straightening it and it hasn't worked .
They'd cost about $40 in Aus but I'd rather wipe my a$$ with a cactus than pay $40 for one .
Got racing in less than 2 weeks
V-One S Racer is offline
Old 10-16-2003, 01:10 AM
  #9521
Taylor-Racing's Avatar
Default Re: Clutch bell?
Haven't got a spare clutch bell - I guess it's the cactus for you, eh.
I have a Fantom clutch bell you could "BORROW" - are they the same thing - not sure.
Taylor-Racing is offline
Old 10-16-2003, 01:47 AM
  #9522
esham's Avatar
http://www.rctech.net/forum/showthre...pagenumber=469
esham is offline
Old 10-16-2003, 02:27 AM
  #9523
alana07's Avatar
thanks pal. btw, when u're using the 3racing alu radio tray supports, you'll need to trim/shave off some plastic from the rx battery holder if you're using the old v1r batt holder, took me about 10 mins worth of shaving!
alana07 is offline
Old 10-16-2003, 09:25 AM
  #9524
Baluga's Avatar
Default V1R servo saver
To all VoneR owners,
I'm looking for an alternative for my tamiya servo saver. Will the Kyosho V1R servo saver fit in a EP kit like TA04? Thanks.
Baluga is offline
Old 10-16-2003, 11:47 PM
  #9525
rrgt_kid's Avatar
if you want to wait a couple of days for the postage try harmony model in hk i recenty brought quite of few for around 14aus each.
jeremy.
rrgt_kid is offline
