Kyosho VoneR Thread
#9511
Originally posted by Manticore
i doubt about the rear down force of this body.
#9512
Originally posted by esham
Oppsss... when through HK forum. Yup..dtm did posted pictures and suggestion. Can't believe it - 3racing !!?
How you finding your MTX3 vs your EVO nowday?
#9513
Originally posted by Taylor-Racing
Maybe.
Remember that when using the conversion kit the only assembly you really keep is the rear bulkheads together with the suspension bits etc. that are attached to it. Pretty much everything in front of the engine is new/different.
Will the rear end bolt onto a V-One XXX chassis?
The Reflex gears are different, I believe.
Maybe.
#9514
Originally posted by AMGRacer
Pretty bad quality from 3 racing right Esham. I think they assume you will also use their chassis plate with the battery holder already included.
AMG, So much thing happen on the weekend, golf match, job outstation etc. I couldn't play much with those babies. Local weather - raining Almost want to get Mini-Z to play indoors I can't really get 100% comfortable with my MTX-3 and EVO yet compare with my existing V1RR. I believe i need more time with them. Still learning to get balance between my driving style and car tweak / setup Meanwhile upgrade my Evo and MTX3 with option parts stuff..
#9515
Kyosho V1RR fuel tanks
Has anyone had any problems with thier v1rr fuel tanks leaking at the seams? I am having a problem, or bad luck, or both. My original one split at the seam and leaked on me during a race. I took this as a one time. I installed a brand new replacement and found it also leaked. Any replacement or quick fixes besides a soldering iron will be helpfull.
#9516
Re: Kyosho V1RR fuel tanks
I have never had a problem with the plastic parts. I did have one tank spring a leak from the foam insert getting crushed and no longer sealing properly. Easily fixed with a $5 part.
#9517
It was definetly the seam on the first tank. Then it appeared the fuel pick up nipple was leaking on the new tank. Also can too short a pressure line cause excessive pressure in the fuel cell during operation forcing air leaks in areas discribed on my fuel cells or in the cap seal.
#9518
#9520
Clutch bell?
Anybody got a (spare) 3D Clutch Bell they can sell me? I gave it to my dad to get the gears off so I could change them to larger ones and I ended up with a bent clutch bell ! I've tried straightening it and it hasn't worked .
They'd cost about $40 in Aus but I'd rather wipe my a$$ with a cactus than pay $40 for one .
Got racing in less than 2 weeks
#9521
Re: Clutch bell?
I have a Fantom clutch bell you could "BORROW" - are they the same thing - not sure.
#9522
Originally posted by alana07
any url for the HK forum?
#9523
http://www.rctech.net/forum/showthre...pagenumber=469
#9524
V1R servo saver
To all VoneR owners,
I'm looking for an alternative for my tamiya servo saver. Will the Kyosho V1R servo saver fit in a EP kit like TA04? Thanks.
#9525
Re: Clutch bell?
jeremy.
