TRF101
#721
Hey guys, I'm a long time offroad electric driver and am looking to try something new and have decided to get in f1. I'm going to be getting the 101, but have absolutely nothing in onroad gear. I've been looking and will probably get the titanium screws out the gate so I have hex screws. But what am I going to need for shims/ spacers for tuning? I'm going to get springs and damper grease. But what else will I need? What are the normal spur/ pinion ranges? I'm going to run a d3.5 21.5 motor. Also, is a low profile necessary or will my Ko rsx servo work well? Thanks in advance for any help.
#722
#723
Ok, I'll probably get the Futaba S9551 servo. With regards to the screws; I really want hexes all around. I will be running shorty Lipos and if the car is underweight, I can add lead weights to it. My intent is to have hex screws all around and still be TCS legal if I can get to one of the races.
#724
The TRF101 already has hex screws all around.
#726
Try a little shim, 0,1 worked for me
I love the kit and it's a very complete and high end kit for the buck!!
Looking forward to run it!!
#727
I've had to use o-rings to remove the play. The steering arm ball-ends were fine, the grey cup/blue alu ball combination used for the side damper had enough play to allow about half a mm movement on the rear pod. There is no way I'd call that great tbh, great would be slopfree out of the box. (within reasonable limits, it still has to move freely, obviously). I'd expect, and be fine with, that in , say, a F109, perhaps even in a F104, but I honestly didn't expect that in a TRF101.
#728
#729
I've been having that same issue with the diff on mine. Seems to me the diff rings are not perfectally flat or the seat it rides on has high spots maybe. just seems to get tight at one spot when I rotate the diff but have not figured out where yet. Switched out the rings same thing, switched out the axle and hub still the same thing. Got me pretty confused.
#731
@ Dan thanks for the setup help sunday man! Hope to race her in 2 weeks time!
I ordered ceramic 1/8 balls to put with a standard kimborough spur 88 since the stock 3mm ones seem to not let plates touch the balls. On road guys still use ceramics in diff correct? For 2wd offroad its pretty hard to not get a chirpy diff with ceramics so I use regular tungsten bfast balls (best IMHO for offroad).
My Tamiya diff seems ok though not heavy. The best I have ever built is a durango diff with bfast balls (not such a fan of the car though), followed by kyosho , schumacher and TLR sorted in terms of smoothness. This one is between a kyosho and a schumacher I would say. Also found it weird the spur gear moves that much between the diff housings but its per spec. All in all love this car especially compared to 17.5 TC which feels too safe and connected until I crash .
#732
I've not noticed a heavy diff after sanding of the diff rings on the TRF101. While you should have some play side to side, I've found sanding removes some of that slop.
I can highly recommend replacing the bearing 1150 with the F103 thrust bearing and it will be butter smooth and require very little maintenance.
I've run this on my F104 and the TRF 101 and it's made a huge difference.
#733
#734
Good meeting you alok!
Whoops, I did forget to mention to you to get 1/8" diff balls. I'm running ceramics in my TRF101. Carbide also works.
F1 is challenging but fun. See you again in 2 weeks!
#735
Yes you too . Yeah I had an old kimborough spur I tried it on and I lost one of the stock 3mm tamiya balls in rebuild haha so was gonna order them anyways. I ordered a machined precision racing 88T spur from ebay because everyone else is out of stock and I am a sucker for machined POM spurs whisper quiet. I read on roads a lot cleaner so ceramics outlast and outperform the carbides!
