Like Tree3Likes
TRF101
Old 09-03-2013, 06:08 PM
  #736
aussierevo's Avatar
Trader Rating: 14 (100%+)
Originally Posted by aloksatoor View Post
Good tip thanks Ill keep that in my tqrc cart for the next big order you used the one piece bearing or the rings and balls separate? If the later what diameter balls?
i use the once piece bearing, has done the job well for 18 months.
aussierevo is offline
Old 09-04-2013, 10:03 AM
  #737
Does the F104V2 motor mount fit the TRF101 rear pod, do the holes line up?
I noticed that the (rear axle) ride height adjusting isn't the same as the V2, that's why i would consider to use the V2 motor mount.
addicted2blue is offline
Old 09-04-2013, 11:26 AM
  #738
theatriks's Avatar
Can someone explain the differences between tamiya 51346 and tamiya 53136 thrust bearings .....are they the same bearing ?...and one pack just comes with more pieces?
theatriks is offline
Old 09-04-2013, 12:04 PM
  #739
aloksatoor's Avatar
Trader Rating: 42 (100%+)
One has the balls already in them. The other is just washers and a center spacer, you probably add your own thrust balls (not sure of the size). Will be a lot trickier to build (You do this for 1/10 off road diffs but the diff housings are very different).
Do you add black graphite hudy grease on the balls as well?
aloksatoor is offline
Old 09-04-2013, 12:34 PM
  #740
theatriks's Avatar
i jamm pack my thrust bearings with the hudy graphite grease.
Old 09-05-2013, 07:03 AM
  #741
Drove it for the first time last night. After some strong words about threadlock not working (and losing one of the upper kingpin ball holders), some loaned parts put me back on the track, and it drove great.
I was lucky to find the important part again, because they're very hard to find (although I assume they can be ordered).
ijdod is offline
Old 09-05-2013, 11:08 AM
  #742
Sockrocker's Avatar
Well after weeks of work and no time, except to browse this thread Finally put together my car! Just need to decide on a paint scheme now.
Sockrocker is offline
Old 09-05-2013, 11:58 PM
  #743
Yeah, there's a missed chance if I ever saw one :P
ijdod is offline
Old 09-06-2013, 12:03 AM
  #744
HeliYogi's Avatar
Trader Rating: 17 (100%+)
How about this one
HeliYogi is offline
Old 09-06-2013, 02:25 AM
  #745
Unfortunately the holes don't line up. The good news is that the TRF101 rearpod is a few mm wider than the F104 V II rearpod.
Johnson40 is offline
Old 09-06-2013, 05:46 AM
  #746
@johnson40,
Thx for the info, to bad the holes don't line up. (could be an improvement when releasing a newer version of the TRF101 in the near future)
The wider rear pod is definately a big improvement when using a speedpassion motor.
I just placed an order @ stellamodels for the last TRF101 chassis kit they have available; looking forward to build and drive it and see the difference in handling over a V2 or the X1 versions.
Old 09-06-2013, 07:49 AM
  #747
yourstruly22's Avatar
Now you just got to come to California to race with use.
yourstruly22 is offline
Old 09-06-2013, 08:42 AM
  #748
Ph3nyx's Avatar
The kit is out of stock at stella since several days ... i deseperatly search the kit at an affordable price , but still out of stock everywere
Ph3nyx is offline
Old 09-06-2013, 10:07 AM
  #749
That's correct, but they still had one for sale in their ebay shop and they have reserved the kit for me, i'm waiting on the invoice to pay for it.
Lucky me
Old 09-06-2013, 10:26 AM
  #750
Jorge T's Avatar
Yep looks like all gone, Tamiya America lists the TRF101 as discontinued! Lucky I got mine before they all went to good homes.
Jorge T is offline
