Tamiya mini cooper
#2913
Originally Posted by xrayroooahhhh
I really would like to start racing the mini's as a second class to my touring car......off the shelf what kit....or chasis.....should I be looking at buying?? Any info would help.....thanks!!
#2914
M03M
Originally Posted by tamiyarcracer
The best bang for the buck is the M03M (Suzuki Swift) you will want to get the 6 bearings needed to complete the kit (4 qty 11mm x 5mm & 2 qty 8mm x5 mm) and some sort of oil filled shock.
#2918
So...whats a Lipo like in an M03? We wanted to know too!
So..we bought one! Click here for our review of the Orion 3200 Lipo/M03 test!
#2919
#2920
nice little 'test report' Tony - just what I was looking for.
A few Qs:
what are the dimensions of the orion 3200 lipo?
(I believe they're shaped just like the shogun packs?)
What lipo charger are you using with this orion pak?
btw, I was told (unconfirmed though..) that the MaxAmps Lipo 4000HV 2S lipo packs will fit.
A few Qs:
#2921
I was on of the racers muahdib4 raced with last week. I think that the 3200 Lipo is the only way to go. I don't know if there is any huge advantage other than no maintenance and less weight, but they are very cool. Imagine 1 battery for an entire weekend of racing...no ballancing, no cooling, no nothin! In our 5 minute race on carpet I was using 600 mah of juice with a silver can!
Oh, and to get mine to fit perfect, I took the ribs off just one of the battery braces...almost invisible...and it fit perfect.
PS...we'll have muahdib4 up to speed before Memphis for sure
#2922
#2923
One reason the LiPo cars are a bit faster on the straights is that a 2-cell LiPo is, nominally, 7.4v while a 6-cell NiCd or NiMH is 7.2v. Doesn't seem like much until you hit it with the calculator and see it's almost 3%. Keep in mind people are having hissy-fits over HUNDREDTHS of volts when buying matched packs...
Scottrik
#2924
Originally Posted by Scottrik
This probably explains, among other things, why these WON'T be legal for TCS...
Scottrik
Scottrik
#2925
A few Qs:
A few Qs:
I have been using the Swallow advance charger for the money it's damn good value and does all kinds of batteries up to 5amps charge rate. I got it a while back with an plane and it's turned out to be a great little allrounder.
The MaxAmps look like an easy fit into the M03 the phisical dimensions are smaller particluarly in height. From the MaxAmps website 44mm X 137mm X 14mm.
The only problem I would have with it is that there is no protection for the cells, the only thing protecting them is heatshrink, in a touring car thats not to bad because the battery is in side the chassis, where as in a mini 2/3rd's of the batteries are hanging out of the chassis unsupported, in a big shunt this could be a problem.
I have seen normal stick packs with double heat shrink bent like a banana because of a huge mini crash, I would imagine the potential for a more "impressive" incident would be much greater with the lipo cells without any external physical protection.
tp
