U.S. Vintage Trans-Am Racing
#9273
I'll be down there to race on the 17th. I'll bring my 25.5 so we can compare. I think you'll see that it's quite a bit slower when geared at 4.0. It seems happier in the 3.7 range. See you then.
#9275
I've got to figure out why my car is faster. WE were practicing with 21.5 novak ballistic and ss's. We had gtb, xtb, tekin rs (spec mode) lrp sphere's. Eveyone was equal except me. I was way faster.
I bought the motor used, could fixed timing adjustment account for this difference? If not should I try a different esc first or motor? Thanks
#9276
Company Representative
What controller were you using?
#9278
Locally, can you guys run our Kinetic 2s and Havoc Pro SC in our non-timing, Sportsman mode?
#9280
As a Tech Inspector, what exactly should I be looking at on the ballistic motor to make sure the timing is per the rules?
#9281
If you are still faster and they are still slower then its all down to driver skill and car setup.
Jimmy
#9282
For complete info about Ballistic motor timing, see the link on the left of this Ballistic page:
Ballistic Spec motors
#9283
All of the PC programmable/AT escs should exhibit the same performance when the "non-timing" setting is selected.
Thanks for including our new escs in your area.
#9284
is there a big difference (if any)..in the ballistic 25.5 motor timing vs the ss 25.5 motor.....if both was cranked all the way up.......from what i was told is that the ballistic motor has more timing then the ss motor.....if this is the case...wouldnt this make VTA still unfair..(not a true spec class)
#9285
Our escs are optimized to run with our BL motors----you do not need to adjust the motor timing.
