Like Tree1Likes
Closed Thread
Old 10-05-2010, 08:28 AM   #9271
DARKSIDE's Avatar
Originally Posted by woodys3b View Post
So, how did the FDR limits work out in Nashville. Curious to find out if you experienced the same thing that we did.
nothing yet...I didnt run...I got your pm...I will pass it on to our RD
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline
Old 10-05-2010, 12:24 PM   #9272
nashrcracer's Avatar
R/C Tech Charter Subscriber
my view was 4.9 21.5 seemed to slow down the fast guys and speed up the slow guys made the field closer. still no 25.5s at my track other then batboy.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline
Old 10-05-2010, 12:53 PM   #9273
I'll be down there to race on the 17th. I'll bring my 25.5 so we can compare. I think you'll see that it's quite a bit slower when geared at 4.0. It seems happier in the 3.7 range. See you then.
woodys3b is offline
Old 10-05-2010, 03:54 PM   #9274
cool I'm really interested in finding out numbers wise it should be right there. might get my ta car ready with my 21.5 and run it with you.
Old 10-05-2010, 04:01 PM   #9275
Victory Side's Avatar
Send a message via Skype™ to Victory Side
I've got to figure out why my car is faster. WE were practicing with 21.5 novak ballistic and ss's. We had gtb, xtb, tekin rs (spec mode) lrp sphere's. Eveyone was equal except me. I was way faster.
I bought the motor used, could fixed timing adjustment account for this difference? If not should I try a different esc first or motor? Thanks
WWW.RICHFIELDRACEWAY.COM
"There are only two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle." ~Albert Einstein
"Do you want to know who you are? Don't ask. Act! Action will delineate and define you.'
Victory Side is offline
Old 10-05-2010, 04:18 PM   #9276
Company Representative
What controller were you using?
NovakTwo is offline
Old 10-06-2010, 09:33 AM   #9277
Tekin RS in Spec mode. There were about 4 of them running. 2 LRP's and 4 Novak's. All equal except for me. In fact one driver had the same car esc and motor, only difference was battery. I had a 5000mah 50c. He had a 5000 35c.
Old 10-06-2010, 09:43 AM   #9278
Locally, can you guys run our Kinetic 2s and Havoc Pro SC in our non-timing, Sportsman mode?
NovakTwo is offline
Old 10-06-2010, 11:17 AM   #9279
Yes, if an esc has a spec mode, I will allow it.
That's what makes this speed thing an issue is when the track operator comes out with a faster car it really makes the eyebrows raise
Old 10-06-2010, 11:29 AM   #9280
As a Tech Inspector, what exactly should I be looking at on the ballistic motor to make sure the timing is per the rules?
woodys3b is offline
Old 10-06-2010, 11:48 AM   #9281
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
3 variables to test, so change out 1 at a time and see where the difference may be. Easiest to swap batteries with one of the other drivers first, then motor, then ESC.
If you are still faster and they are still slower then its all down to driver skill and car setup.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline
Old 10-06-2010, 11:51 AM   #9282
All of our Ballistic motors have a timing label; this label shows either "N" or "30" in the label's center---this is our factory pre-set 30 degree timing.
For complete info about Ballistic motor timing, see the link on the left of this Ballistic page:
Ballistic Spec motors
NovakTwo is offline
Old 10-06-2010, 11:57 AM   #9283
All of the PC programmable/AT escs should exhibit the same performance when the "non-timing" setting is selected.
Thanks for including our new escs in your area.
NovakTwo is offline
Old 10-06-2010, 12:07 PM   #9284
is there a big difference (if any)..in the ballistic 25.5 motor timing vs the ss 25.5 motor.....if both was cranked all the way up.......from what i was told is that the ballistic motor has more timing then the ss motor.....if this is the case...wouldnt this make VTA still unfair..(not a true spec class)
starrx is offline
Old 10-06-2010, 02:21 PM   #9285
All of our BL motors (from the beginning) have been set here at the factory to 30 degrees (see info linked above); both the SS Pros and the Ballistics are set the same. The SS Pros were not designed to allow timing adjustments, although racers changed the factory timing anyway.
Our escs are optimized to run with our BL motors----you do not need to adjust the motor timing.
NovakTwo is offline
Closed Thread
Georgia Vintage Trans Am Racing shadow102 Georgia Racing 725 02-24-2012 09:56 AM
Vintage Trans Am Scottrik Electric On-Road 47 02-24-2012 08:21 AM
Vintage Trans-Am TC hlpressley R/C Items: Wanted to Buy 5 10-23-2008 04:00 PM
Thursday Vintage Trans Am racing at Victory in Green Bay Brian F Wisconsin & Illinois Racing 13 05-10-2008 08:37 AM
