NEW XRAY T2
#1966
Originally Posted by Juan Aveytia
Harsh, why didn't you counter sink everyhole, including the aluminun. I gotcha beat. Looks real good.
#1967
Originally Posted by HarshGuy
and the clearance on Jaco foams with the tamiya 6 mm nuts (clooossse),
#1968
Originally Posted by HRCRACER123
I was wondering with those 6mm Tamiya Hexes how much more clearence did they give you as far as rubbing the steering knuckle than the stock ones. I really cant tell on that one pic? How much more does it bring it out?
#1969
Does anyone know what pound the silver and copper springs are that come in the T2 kit?
#1971
#1973
Junior- This is from the Xray Forum.
"The gold springs included in the T2 kits are similar to the #308384 - Spring-Set D=1.5 (15 LB) Blue-Green (4) and the silver ones are similar to the #308385 Spring-Set D=1.6 (20 LB) Light-Blue (4) but they have different, more progressive, dampening characteristics."
#1974
Thats weird in your post #1952 you said that the Tamiya 6mm hexes fit perfectly. Whats the deal.. I was going to purchase them..
#1975
Yea that pic is with the 6 mm hexes ...I never tried the stock ones i.e. to tell you how much more clearance, all I can say is with the 6 mm it's clooosssseee, so I can only assume the stock ones would way rub on the knuckle.
#1976
First time with an Xray car...a few questions
On the T2 foam set-up sheet included in the Kit. it states for the rear toe-in overall at 2 degrees and mentions to use a a .75 spacer in the in the rear wheel base spacer....
now the manual mentions to use for the rear wheel base spacers 1.5mm towards front and 2x 1.5mm spacers in the rear.
Question:
How does the .75 spacers per the optional set-up sheet work. do you remove one of the 1.5mm spacers and replace it with the .75?
PS: Hey Unrath what set-up did you guys use at Mimi's
Question:
#1977
#1978
Hi Carl,
The 1.5mm spacers are considered "track width" spacers and used on the front and rear of every suspension holder. The extra 1.5mm spacer in the rear holder of the rear arm hinge pin provides too much toe (for carpet) and it's replaced with the .75 mm spacer. If you left that .75 mm spacer out, you would have only the 1 degree of toe provided by the hub.
Ralph
Ralph
#1979
Hrcracer, Harsh was talking to me about counter sinking the top bulk heads. XRAY hexes are 5mm. You have to add 1mm to clear the steering knuckles. So, the tamiya 6mm are perfect. I believe 3racing also makes 6mm hexes for tamiya cars.
I was so confused.
#1980
Did that rookie quote RDX info on the T2 thread again....LOL See ya on the 28th.
