Yokomo MR-4TC SD
did you check to see if the bladder in the shock cap is ripped or something? maybe there's not enough oil in it? If the shaft moves smooth then there's no reason to replace it, it sounds like a simple problem that you just haven't caught yet.
Yok shocks VS TRF shocks
Matt Howard, thank you for your input, actually I did not check the bladder, only the shaft and I replaced the white o-ring by a black one that came with the kit but it did not work..
Also, when I compare the yok shocks to my Tamiya TRF they aren't poping out as far and fast and I'm using the same oil, now I know the tamiya shocks are the best out there but I don't know if such a difference is normal...
The Yok shocks still feel nice and smooth, BTW I built them carefully and only had one not working at all...
How are you shocks working? and how would you compare them to the Tamiya's?
Thanks!!
Thanks!!
Hi all,I'm trying to sort out a few handling probs with my car and wan't to clear up a question that's been bugging me.When setting droop - is that set by the suspension arm adjusting screws with the shocks attached or unattached to the arms?Hope this makes sense.
I normally set droop with the droop screws, with the shocks disconnected. Then I adjust the shock length if necessary, then reconnect the shocks.
Excellent,thanks Horatio.Thats the way I've been doing it.
Sorted!
Ah not totally sorted.I've still got to sort out the rest of my handling issues.That just eliminates one area.
hi guys, for diff...do u guys sand the diff plate?
But only after I have used them already...they are really nice new.
Most of the time I just buy new ones...takes less time. Although I have seen guys scuffign them with 2000 grit before they install new ones also...Just a thought.
Stephen <><
Drivetrain wobling
Guys,
Since I have my diff still wobbling do you think this is why the rest of the drivetrain (spur, shaft) has some side to side wonling also?
Im waiting for some parts from speedtech to rebuild a new diff and hopefuly get rid of the woble but I hope its coming from the diff
Re: Drivetrain wobling
Originally posted by Tbevofreak
Guys,
Guys,
Someone else posted on here that you may have over tightened the spur gear, onto the spur gear adapter, torqued it a little and now it wobbles. Its a common problem, just loosen the screws and tighten evenly. No need to torque it down, that's why use thread lock to hold the screws in.
Compare a one way to a diff in terms of constuction. The one way is a machined piece in the center with one way bearings pressed in to place by machine, very tight fitment. Now take look at a diff, molded, user assembled, more prone to variances.
For zero wobble, use a spool in the rear, and a one-way up front. Don't try it, 1/8 setup, good when you have large rear tires, and can "scoot" tires through a turn.
rc_bam, thanks for your post I understand that diff gears don't come out of the mold all perfect
But I m trying to find out how the diff wobling can influence the rest of the drivetrain (spur and shaft) by making it wobling also because the wobling changes when I shim the diff differently
I'm wondering if all this isn't a drivetrain alignement problem..?
How do you align your drivetrain on the SD/SDW?
Hope you can still bother with me!
Cheers!
Cheers!
Cheers!
Cheers!
As far as assembly goes, went by manufacturer's instructions in the manual, gave it a good starting run, and started to make adjustments. Nothing special there.
RETARDED ME
Thanx Shook... -JB
