Old 05-11-2005, 10:33 AM   #13486
Matt Howard's Avatar
did you check to see if the bladder in the shock cap is ripped or something? maybe there's not enough oil in it? If the shaft moves smooth then there's no reason to replace it, it sounds like a simple problem that you just haven't caught yet.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 05-11-2005, 02:02 PM   #13487
Default Yok shocks VS TRF shocks
Matt Howard, thank you for your input, actually I did not check the bladder, only the shaft and I replaced the white o-ring by a black one that came with the kit but it did not work..
Also, when I compare the yok shocks to my Tamiya TRF they aren't poping out as far and fast and I'm using the same oil, now I know the tamiya shocks are the best out there but I don't know if such a difference is normal...
The Yok shocks still feel nice and smooth, BTW I built them carefully and only had one not working at all...
How are you shocks working? and how would you compare them to the Tamiya's?
Thanks!!
Tbevofreak is offline   Reply With Quote
Old 05-12-2005, 03:00 AM   #13488
Yokibear's Avatar
Hi all,I'm trying to sort out a few handling probs with my car and wan't to clear up a question that's been bugging me.When setting droop - is that set by the suspension arm adjusting screws with the shocks attached or unattached to the arms?Hope this makes sense.
CORALLY RDX
AERCCC Member #18
Yokibear is offline   Reply With Quote
Old 05-12-2005, 03:40 AM   #13489
Horatio's Avatar
I normally set droop with the droop screws, with the shocks disconnected. Then I adjust the shock length if necessary, then reconnect the shocks.
Horatio is offline   Reply With Quote
Old 05-12-2005, 03:44 AM   #13490
Yokibear's Avatar
Excellent,thanks Horatio.Thats the way I've been doing it.
CORALLY RDX
AERCCC Member #18
Old 05-12-2005, 03:54 AM   #13491
Horatio's Avatar
Sorted!
Old 05-12-2005, 03:58 AM   #13492
Yokibear's Avatar
Ah not totally sorted.I've still got to sort out the rest of my handling issues.That just eliminates one area.
CORALLY RDX
AERCCC Member #18
Old 05-12-2005, 07:28 AM   #13493
ali_g's Avatar
hi guys, for diff...do u guys sand the diff plate?
ali_g is offline   Reply With Quote
Old 05-12-2005, 07:32 AM   #13494
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Yes with 2000grit
But only after I have used them already...they are really nice new.
Most of the time I just buy new ones...takes less time. Although I have seen guys scuffign them with 2000 grit before they install new ones also...Just a thought.
Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 05-12-2005, 08:07 AM   #13495
Default Drivetrain wobling
Guys,
Since I have my diff still wobbling do you think this is why the rest of the drivetrain (spur, shaft) has some side to side wonling also?
Im waiting for some parts from speedtech to rebuild a new diff and hopefuly get rid of the woble but I hope its coming from the diff
Old 05-12-2005, 10:25 AM   #13496
rc_bam226's Avatar
Default Re: Drivetrain wobling
Originally posted by Tbevofreak
Guys,
Well, after talking to a few drivers who went from 1/10 elec to 1/10 nitro and up, ball diffs have a natural "wobble." The reason for that is you putting to halves together that do not interlock, and there is a variable surface joining the two halves, the diff gear. If you notice that diff screw that holds the two halves together has a little play, it could just be the halves are not perfectly aligned.
Someone else posted on here that you may have over tightened the spur gear, onto the spur gear adapter, torqued it a little and now it wobbles. Its a common problem, just loosen the screws and tighten evenly. No need to torque it down, that's why use thread lock to hold the screws in.
Compare a one way to a diff in terms of constuction. The one way is a machined piece in the center with one way bearings pressed in to place by machine, very tight fitment. Now take look at a diff, molded, user assembled, more prone to variances.
For zero wobble, use a spool in the rear, and a one-way up front. Don't try it, 1/8 setup, good when you have large rear tires, and can "scoot" tires through a turn.
rc_bam226 is offline   Reply With Quote
Old 05-13-2005, 06:47 AM   #13497
rc_bam, thanks for your post I understand that diff gears don't come out of the mold all perfect
But I m trying to find out how the diff wobling can influence the rest of the drivetrain (spur and shaft) by making it wobling also because the wobling changes when I shim the diff differently
I'm wondering if all this isn't a drivetrain alignement problem..?
How do you align your drivetrain on the SD/SDW?
Hope you can still bother with me!
Cheers!
Old 05-13-2005, 08:32 AM   #13498
rc_bam226's Avatar
Cheers!
The only only thing that I can think of that would wear would be the ring gear(diff/one-way), and the input gear. But that is normal wear-and-tear. Over time and usage the gears will break in.
As far as assembly goes, went by manufacturer's instructions in the manual, gave it a good starting run, and started to make adjustments. Nothing special there.
Old 05-14-2005, 12:39 PM   #13499
RETARDED ME
Old 05-14-2005, 02:06 PM   #13500
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Thanx Shook... -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
