Tamiya TRF416 / TRF416WE / TRF416X
#1591
I take it fab is running TF5 "shin"stallion now? oh well good luck to him!
#1592
Why do I need to listen to you.... I tried your set ups b4 and they did not work out for me.......But they do work good for you and that what counts.
Hopefully your grades in school are as good as your knowledge about a 10th car...
These 1/10 kits are not a NASA project kid....
I do not need any help with sweeper arms (scrub)...... or toe out. I need stronger spur gears.
#1593
As for the bones:
TAM51092 46mm
TAM53501 42mm
#1594
Tips etc
Hey all,
Quick document here. Bascially pulling together as much of the advice I can for the 416. This document is going to form the basis of the tips and tricks section on my site when I get round to it ().
Let me know your thoughts, and if anyone has anything else to add.
Cheers
Ed
Cheers
Ed
#1595
I used the Parma brick and cut it down.
Hmm, looks like the PDub bumper is out of stock. I bought mine at Nexus though. Perhaps someone can suggest another brand of hard bumper that works on the 416? I know Parma sells a blank that you can cut down on your own. There's a PDub forum on this site somewhere, but don't know what the story is on whether or not they're making new stuff.
As for the bones:
TAM51092 46mm
TAM53501 42mm
As for the bones:
TAM51092 46mm
TAM53501 42mm
#1596
Hey all,
Cheers
Ed
Cheers
Ed
#1599
#1600
Just took my newly acquired 416 for a rubber/carpet spin with the Gilles TRF setup…..WOW…WOOW….never tried a more smooth and crisp driving.
This car is really a winner
#1601
Hi,
Don't know if this is a noob question but do you guys CA the diff rings to the outdrives for the 416?
Cos there's no D on the outdrives or the rings.
#1603
Hey, Ed.... for the diff section in your build tips. Maybe you can add plugging the long diff end with a foam pad. And taping over the diff setting screw hole. This will keep any and all dirt from entering the thrust bearing for a long lasting, best performing diff.
#1604
Hey all,
Cheers
Ed
Cheers
Ed
perhaps this goes without saying, but i would advise the use of threadlock in most of the build. in my first weekend racing the car, many screws came loose or backed out despite how snug i tightened them.
#1605
I know this is the 416 thread but could any of you guys help me locate a set of Square R/C EVO4 Front Steering Knuckles/uprights for my 415msx mre.
thanks
thanks
