Kyosho Ultima RB6 & RB6.6 Car Thread
subscribing, kind of a newb to buggies but I think the Engineering and quality is superior to AE / Losi.
Am I wrong?
Primarily will be running on a nice indoor track, just wanna have fun with everyone else.
Over 40 racer
Am I wrong?
Over 40 racer
Anyone use or have used the j concept front brace? For some strange reason mine pops off very easily. In fact this past race weekend it popped off twice. Small bobble here and then plink it flies off. Any advice?
I have one and it did pop out once but it was when when I broke the front arm at the pivot. I'll keep an eye on it. Makes me wish I'd got the blue one cause black is hard to see on clay
I have been experimenting with various setups on my RB6 and still always end up back with my stock mid motor setup with which I start with at most tracks.
The one thing that I typically fight with my setup is rear grip. I am looking for some advice on which direction to proceed to get more rear grip. I am looking for more low speed side bite as well as forward traction. Forward traction is the bigger problem of the two. I need to be able to pull more throttle. The setup is not bad, it is just not a setup that I feel that I can push when I need to in the mains. As soon as I push the car, I overdrive the grip level in the chassis. My setup is attached. Any advice is greatly appreciated.
Thanks!!
Thanks!!
I use these threaded hinge pins on my kyosho rb5. These will keep the front brace captured so the brace can't ever pop off.
Thanks!!
Thanks!!
Thanks!!
Thanks!!
The only change that had large gains for me are battery placement and rear droop. I have found that the RB6 is sensitive to where you place the battery. For me moving the battery to the rear got me more rear grip to the point where I needed less rear weight to gain some rotation back. Also less rear droop restricted the weight shift to the front planting the rear during cornering and exit. For me this is what helped.
I feel that the true advantage to a shorty pack is not just the weight savings (which may not always be a benefit) it's the ability to shift the weight along the chassis as a tuning option. Droop also plays a huge role in this case which controls the amount of weight being shifted front and back.
Next, your roll centers are a bit out of wack. Chang both front and rear outer to a 1mm shim. Your rear camber link is pretty short on that setup, go in on the tower side and maybe out 1 hole on hub.
Move rear top shock location in one or two holes.
I'd start with those changes and see where you are at. You can also also reverse steering rack so arrow is pointing back, this will calm down the steering.
Try all that and let me know what you are feeling.
P.s makes sure your front foams haven't gone too soft and the tires aren't ballooned, this will make almost any setup undriveable
I too had the same concerns you are having. I had played with roll centers, ride height and even rear track width to try and gain more rear traction. Sure the results were evident but only in small amounts.
Ok, I see a few things you can try that I think would help out. First, 4deg of toe is a lot ananus great on loose dirt tracks for forward bite but might actually lower traction on hard packed ones, especially side bite. Try b-out/ b-out.
I have also noticed that a lot of people have been reversing the steering rack. I didn't know what that particular change does, so I never tried it, but after your advice, I think that will help tremendously. I have been running Three Rib tires to help calm the steering down, but if I reverse the steering rack, I might be able to go back to running a pin front tire.
I will also try the different shock mounting locations as well.
Thanks!!
In my opinion I won't say superior the engineering and quality is definitely superb!
RB6 To RT6
Hi been looking for the thread, but can't seem to find it, I would like to convert my RB6 to the RT6 if it's cheap enough, thanks guys
might not be that bad..i converted my rb5 to rb6..main thing was the chassis. i went on amain to compare parts and pics..and you can see whats compatible..might run you about $200 maybe a little less?..u figure the chassis and cvd will be the most..arms,towers,body mounts and a body also quick change hubs.. go for it!!
Just finished the build of my rb6, totally stock. Man the Kyosho instructions aren't very good. I also had issues with a couple screws not being used where the manual said they were, and instead other screws needed. The wheels that I got are slightly different colors too. One is a very Snow White and the other is almost a light eggshell white...little disappointed in that but...
The car is still amazing! Makes my b4.2 look cheap.
I was surprised how long the build took. Especially considering this is the second rb6 I have built and I have had experience with the rb5 as well. Taking my time to make sure everything was working and fitting properly it took about 4.5 hours. My 22 2.0 took only about 3 hours building the same way.
