Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 12-17-2014, 10:22 PM
  #11281
^^^^ exactly. My F main skill can't tell the difference between 5 and 20 dollar springs
CaseyD is offline
Old 12-18-2014, 03:12 AM
  #11282
motorfinger's Avatar
Trader Rating: 18 (100%+)
Hey Panda, I have a Shurrspeed V3 17.5. I will be at the Clubhouse this Saturday for the 1st Anniversary race.
motorfinger is offline
Old 12-18-2014, 04:11 AM
  #11283
ThePanda's Avatar
Trader Rating: 68 (100%+)
Thanks but I'm going out of town this coming weekend to see some family.
ThePanda is offline
Old 12-18-2014, 05:31 AM
  #11284
Does it matter on the b6 or sct which side the ball diff adjustmenmt screw is on? Drivers or passenger? thanks
katoom007 is offline
Old 12-18-2014, 06:15 AM
  #11285
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
I always put it on the opposite side of the slipper. This way, it is a lot easier to adjust it and I never had a problem with it coming loose.
Kraig is offline
Old 12-18-2014, 06:39 AM
  #11286
Mechintosh's Avatar
Originally Posted by WagwanBumba
Hey Mechintosh - are you running RM or MM?
MM mostly. I have 2 cars, 1 RM 1 MM. I run the MM most of the time.
Mechintosh is offline
Old 12-18-2014, 07:35 AM
  #11287
lewis4x4's Avatar
Yes, put the screw head on the opposite side of the spur/pinion. As stated, it is easier to adjust but it also will not loosen as you drive.
lewis4x4 is offline
Old 12-18-2014, 08:23 AM
  #11288
ThePanda's Avatar
If you build it correctly it shouldn't loosen anyways. You run the diff typically with the adjustment on the non slipper side just because it's easier to adjust. Case in point mm vs rm which flips the diff 180 degrees.
ThePanda is offline
Old 12-18-2014, 09:26 AM
  #11289
Potoczak's Avatar
Trader Rating: 120 (100%+)
+1. Way easier to adjust.
Potoczak is offline
Old 12-18-2014, 09:28 AM
  #11290
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
So if you put it on the other side will it tighten as you drive , doesn't matter....whatever side is easier for you to adjust from.
Matt Trimmings is offline
Old 12-18-2014, 03:02 PM
  #11291
thank you all for your help. I appreciate it.
Old 12-19-2014, 09:18 AM
  #11292
rosko's Avatar
Anyone know if or when a world's kit is coming?
rosko is offline
Old 12-19-2014, 10:38 AM
  #11293
aloksatoor's Avatar
Trader Rating: 43 (100%+)
Dunno, the worlds car was not that different than the stocker what can they upgrade in the worlds kit? Maybe a rear MM bulkhead which was beefed up and a few front brace/hinge pin holders? This is the reason I run Kyosho, the worlds team pretty much runs 99% of the kit I run unlike brands.
I would however love an actual full MM body looking like the blade.
aloksatoor is offline
Old 12-19-2014, 02:36 PM
  #11294
My LHS is having great difficulty keeping Kyosho spur gears on the shelf. I know that between my RB6 and my RT6 I've been through 7, and the other RB6 driver that races with us has DNF'd at least a couple of times.
I just replaced my gearbox, bearings, top shaft and pinion. I made sure everything was super free in the gearbox and that my slipper was set so that it barely raised the front wheels.
Right now I'm debating whether it is spur gear #8 or b5m #1
phillypete is offline
Old 12-19-2014, 04:10 PM
  #11295
beedee's Avatar
My first post here in the Kyosho world. I'm acquiring a used RB6 hopefully tomorrow and want to put a new body on it, rear motor configuration. What is one of the best looking bodies in your guys opinion? (i know its subjective, but still looking for a good place to start looking. JConcepts Finnisher perhaps?
beedee is offline
