Like Tree5Likes
SC10 4x4 Thread
Old 11-24-2011 | 08:22 AM
  #11416
MantisWorx's Avatar
Originally Posted by Evil Genius jr.
I'm not knocking rcshox's product in any way. But as an alternative to the ACK bar wouldn't one be able to switch the stock bar around? I test fitted it last night and fits fights but you have to grind away the bell-crank like in the ACK bar install manual (which I am not willing to do right now). Granted it's not adjustable and probably no where near as good as the real thing but for those on a tight budget like me it might just work. I remember people did the reverse on the blitz to get more steering so there's no reason why it cant be done here.
Once again I think rcshox's solution is much better but this might work with no additional parts.
if you flip the stock bar you still have to grind the steering arms.
MantisWorx is offline
Old 11-24-2011 | 08:41 AM
  #11417
Wild Cherry's Avatar
Originally Posted by 4x4slasher
so, after a time of arguing with myself, i finally picked up a sc10 4x4, am wanting to power it with a novak HV 6.5 turn and Novak HV Pro Esc, any recommendations for pinion, spur, upgrades?
assuming its a 550
try 15 first or 16t , may need to use a little boost too ...
Wild Cherry is offline
Old 11-24-2011 | 08:50 AM
  #11418
thanks, will give it a go
4x4slasher is offline
Old 11-24-2011 | 09:08 AM
  #11419
Im going to be running a TENSHOCK S411 4600KV and a Hobby-wing XERUN SCT Pro ESC. Anyone familiar with any of this. what gearing should I use. Any advice for me Ext......
dougwalter911 is offline
Old 11-24-2011 | 09:10 AM
  #11420
Originally Posted by symmetricon
You can use the pin mod while using the clutch basket, I personally dont though. The real problem is the inconsistecy of the stock slipper pads, they do not supply the right amount of slip n grip. In most cases you need to lock them down to work without over heating the slipper assembly, but the garodiscs found at http://rcshox.com/shoxshop/catalog/i...hp?cPath=23_26 give you adustability between (too much slip and no grip) and (locked down). They are sold in sets of two(stock slipper assembly) and three(clutch basket assembly). the clutch basket shines on high grip tacks, which I do not run.
I really appreciate your help. Thanks again
Old 11-24-2011 | 09:42 AM
  #11421
symmetricon's Avatar
it does depend on the track size. i have run that motor on a medium/large covered outside track, and i was geared 14/62.
symmetricon is offline
Old 11-24-2011 | 09:44 AM
  #11422
racerx1920's Avatar
how much and where do i have to grind off? i fliped my stock bar and the strearing is locked it will not turn. the rod end are hitting? do i have to grind the rod ends too?
racerx1920 is offline
Old 11-24-2011 | 09:47 AM
  #11423
If you look at the instructions posted of rcshox, it details where to gring material off. http://www.rcshox.com/instructions/ackbar-installation/
Old 11-24-2011 | 09:58 AM
  #11424
Evil Genius jr.'s Avatar
Just got done from a quick run in the street. Motor and ESC cool to the touch.... Slipper burned my hand . Clutch basket time!
Evil Genius jr. is offline
Old 11-24-2011 | 10:35 AM
  #11425
racerx1920's Avatar
thanks
Old 11-24-2011 | 10:48 AM
  #11426
MantisWorx's Avatar
i dont recommend flipping the stock bar, it moves the ackerman way too far back which is why on my bar i dont have a mounting point that far back. whatever you do dont grind the rod end, it will pop off everytime you land funky, only grind the arms.
Old 11-24-2011 | 10:49 AM
  #11427
MantisWorx's Avatar
garodiscs my friend!!
Old 11-24-2011 | 11:34 AM
  #11428
CraigMBA's Avatar
I changed the rear pivot to a TeamSTRC unit, on a hunch that the binding of the inner hinge pins had something to do with the A arms distorting. I haven't ran it long enough to know for sure, but my truck gained like 7mm of ride height by simply changing that part.
The rear arms were that bound up. And yes, the truck was clean before.
I'd buy the front one if it had the delrin pivots installed in it.
CraigMBA is offline
Old 11-24-2011 | 11:52 AM
  #11429
Mac The Knife's Avatar
Clutch Basket.
Mac The Knife is offline
Old 11-24-2011 | 12:31 PM
  #11430
Clutch Basket.
Both!
