Like Tree5Likes
SC10 4x4 Thread
Old 11-07-2011 | 06:23 PM
  #10396
CraigMBA's Avatar
Originally Posted by Cameron Kellogg
Kind of feels better at first but was hard for me to be consistant with lap times wise.
I think it depends on what surface you are running on. If you are on a low bite dry slick or blown out, fluffy loam, or rough track with lots of bumps out of the corners, I think the pin is better.
If the surface is high bite, and smooth without the pin might be better.
I had good luck running HD pads inside and outside, standard pad in w/ the original, not imitation Mac The Knife slipper basket and no pin. IMO running three HD pads and pinning the front shaft is my preferred setup because it's easier on the tracks I run on.
Cameron obviously hauls a** so it's hard for me to argue with him. I'd like to think that if we raced on each others' tracks we'd come to the same conclusion.
CraigMBA is offline
Old 11-07-2011 | 06:29 PM
  #10397
CoyoteSlash's Avatar
OK then I am not crazy. I am faster around PRCR with the slipper and the 19th over the pin mod set up.
Also: Those nearly 8th Scale outdoor tracks that are high speed tracks, the Pin is I think beyond superior to the slipper. There is 'no' way to keep up with the losi's in that situation.
PRCR and whatnot. a 'true' short course. I could easily believe the slipper reigns. I break my back end out to get around the corners pinned. That isn't going to cut it on a indoor sticky deal.
CoyoteSlash is offline
Old 11-07-2011 | 06:43 PM
  #10398
speedracer109's Avatar
what are you guys doing about dirt getting into the spur ? every time i run i have to stop and remove the cover and it is getting old . so much i dont enjoy racing the truck . i am running the 48 pitch.
speedracer109 is offline
Old 11-07-2011 | 06:47 PM
  #10399
uh... wait. That makes no sense. How are you getting dirt in the Belt tunnel? Are you running the Basket with the spur cover chopped off?
Old 11-07-2011 | 07:00 PM
  #10400
JEFFs SC10's Avatar
Originally Posted by MantisWorx
yup, PM me! but be forewarned that i am a flamer and know absolutely nothing about my multicolored molded copycat pistons, and all of my tools are lefthanded!!
PM sent
JEFFs SC10 is offline
Old 11-07-2011 | 07:13 PM
  #10401
MantisWorx's Avatar
Strange, the track i ran on the video was high bite and smooth and no pinned sucked in my opinion!! i had no problem getting out of turns. interesting how everyone is getting away from pinned in less than a week! LOL
MantisWorx is offline
Old 11-07-2011 | 07:14 PM
  #10402
Chad Smith's Avatar
There is no way dirt should be getting in the spur gear enough that you have to stop running. Are you running the belt covers?
Chad Smith is offline
Old 11-07-2011 | 07:16 PM
  #10403
JEFFs SC10's Avatar
I been out of the game for a couple months. What exactly does pinning do? How does this help performance?
marcus i'm sending you my truck for some serious modification!
Old 11-07-2011 | 07:33 PM
  #10404
jsamarin's Avatar
its probably coming in through the motor plate. if you have a close look at it with the gear cover off, u will see that the motor dosent fully cover up the holes. 1 way to fix this is to set your mesh, then put some tape over the holes, preventing dirt from comming in.
jsamarin is offline
Old 11-07-2011 | 07:50 PM
  #10405
This truck is STUPID about how different it is per driver. anyone can drive a Losi, any style driving. We have to tune more than any other truck i've ever ran (and that's not saying alot) for 'ourselves'. I make the truck look good. Offer to let someone drive it and they scowl at it. It's unforgiving imo. But this isn't a bad thing imho.
Old 11-07-2011 | 07:54 PM
  #10406
MantisWorx's Avatar
VERY true!! its starting to come full circle though, i think with the EXO chassis,ACK bar and what i got coming in a few weeks will complete the puzzle!
Old 11-07-2011 | 07:55 PM
  #10407
SourDieselX's Avatar
i have my order in for the exotek chassis
SourDieselX is offline
Old 11-07-2011 | 07:57 PM
  #10408
Okay Guys. I need Help. This is starting to piss me off.
1:
- Truck's dialed. You all know i've gone through 2 idlers so far.
- Just installed a brand new belt (old one lasted 6 months)
- clicker Teeth are spanking sharp and new looking, and locked out. (full 4x4)
- Set to stock tension
- 550 castle 1415, no basket, pinned Slipper
I, for God's sake... Cannot find this clicking noise. I know some have asked about it... but It's not the belt skipping. I *idiot* torqued down the belt just to prove to myself that the belt wasn't skipping and of course stretched the belt out pre-maturely. It's more of a plasticky click from what I 'think' is coming from the rear.
It sounds EXACTLY like the belt skipping but it's under acceleration until I get to speed and it stops. Sounds like it's coming from the rear gearbox. But I have it open and everything's clean and nice. I'm pulling my hair out. I stopped driving on a BEAUTIFUL sunday because it was upsetting me. No loss of power, nothing, just a blech clicking.
2:
My Diffs. All i've ever read (if I missed it, I apologize) was your O-rings are causing the floppy drives. Well mine look great and My drives are getting "BAD" wobble now. I was ignoring it and not worrying but now it's getting drastic wobble.
They look fine. Is it the Brass inner bushing that's the real problem? Thanks for the help as always guys.
Old 11-07-2011 | 08:01 PM
  #10409
MantisWorx's Avatar
1:
2:
i had a similar sound and it did it until it broke the belt in half!! after inspection the rear pulley was getting worn, you really couldnt tell until i took it off.
the bushings are the culprit, they need to be made of steel instead of soft bronze, the oring is just a seal.
Old 11-07-2011 | 08:10 PM
  #10410
That's what I thought (bushings) balls...
Yeah. The puley looks fine... I guess? Gah....
