RC10B4.1 FT/WC
Old 11-04-2011 | 12:17 PM
  #7141
proraptor's Avatar
If you guys use a savox shorty servo it makes it really easy to add weight behind the servo
proraptor is offline
Old 11-04-2011 | 12:18 PM
  #7142
aeRayls's Avatar
Originally Posted by Matt Trimmings
It is actually placed behind the servo (if you have room) or in front of the battery.
I've seen Brent have it both ways. (in front/ behind)
Normally I like a no weight car except on very high bite indoor tracks to help calm the car down.
aeRayls is offline
Old 11-04-2011 | 12:37 PM
  #7143
Jmuck69's Avatar
That is TMI.
Jmuck69 is offline
Old 11-04-2011 | 03:54 PM
  #7144
YankeeFan123's Avatar
Originally Posted by Midnight
On Brent theilke setup it calls for ghea #3 rear piston. What regular ae piston would compare? Also he calls for 3/4 oz behind servo? How do u put weight behind the servo? Pics would be nice. Lol
dont have a pic but here you go lol.
________ _______
| nnnnnn | |nnnnnn |
| nnnnnn | |nnnnnn | <---- weights
| nnnnnn | |nnnnnn |
| nnnnnnnnnnnnnnnn | <-----The servo
| nnnnnnnnnnnnnnnn |
| nnnnnnnnnnnnnnnn |
| nnnnnnnnnnnnnnnn |
| nnnnnnnnnnnnnnnn |
| nnnnnnnnnnnnnnnn |
YankeeFan123 is offline
Old 11-04-2011 | 04:19 PM
  #7145
mxracer458's Avatar
________ _______
| nnnnnn | |nnnnnn |
| nnnnnn | |nnnnnn |
| nnnnnnnnnnnnnnnn |
| nnnnnnnnnnnnnnnn |
| nnnnnnnnnnnnnnnn |
| nnnnnnnnnnnnnnnn |
| nnnnnnnnnnnnnnnn |
Haha I get it,but for reals,it's pretty tight between the servo and the plastic behind the servo.
mxracer458 is offline
Old 11-04-2011 | 04:22 PM
  #7146
mxracer458's Avatar
All done converting my sc to stadium truck!can't wait to get back out with a truck.anyone ever try running silver springs in the reAr?
Old 11-04-2011 | 04:44 PM
  #7147
jkirkwood's Avatar
The savox short servo is almost 1oz lighter than a regular sized servo that many of the team guys run. Keep that in mind if you are copying setups.
jkirkwood is offline
Old 11-04-2011 | 04:56 PM
  #7148
Tiggertrucks's Avatar
Does anyone have a pic of where all the weights go on the buggy and truck?
Tiggertrucks is online now
Old 11-04-2011 | 11:00 PM
  #7149
Jerz616's Avatar
Just got my new b4.1 home and ready to build. Pulled everything out to set up and guess what. I have heard of some kits missing a few things like wheel nuts. Mine has them, but I am missing a whole bag of shocks. That really sucks. Anyone ever had this bag missing? I know everyone says the customer support is great and they ship missing parts, but do you really think they will send me a bag of shocks? I guess we will see.
Jerz616 is offline
Old 11-05-2011 | 06:33 AM
  #7150
air8's Avatar
Yes they will. Just gotta contact them.
air8 is offline
Old 11-05-2011 | 06:54 AM
  #7151
idrummerboy13's Avatar
Default speaker wire
alright so i am going to wire up my speaker wire to all my tronics, i found 50 feet of schosce for a good price so why not...i noticed one half of the wire has a positive sign on it. So does it matter what i wire to what on my sxx? or its all the same as long as i solder to right spots on the motor? this stuff is really nice btw, looks like some high quality stuff, but i am no speaker wire tech
idrummerboy13 is offline
Old 11-05-2011 | 07:11 AM
  #7152
racer53's Avatar
Correct...it does not matter if the wire says +
or - on it, as long as you keep the wire contacts the same as they where with the old wiring...
Racer53
racer53 is offline
Old 11-05-2011 | 08:35 AM
  #7153
yes it is tight and since i have a bigger servo than most i need to loosen the three screws above the servo or elsewhen the wheelsare moved side toside then it clicks in the middle so i have to loosen the screws to fix that problem
Old 11-05-2011 | 09:58 PM
  #7154
Has anyone been using Kyosho 12mm hex rear rims with the b4 or b44 hex conversion? Do they work?
Breeze is offline
Old 11-06-2011 | 12:22 AM
  #7155
Registered User
Yes, they do work. I have used both the Losi 22 wheels and the Kyosho. You need to drill out the axle hole a little bit to get the axle to fit but that's it. I also just got a set of the DE racing wheels and do like them better (no mods needed)
Ryno B4.1 is offline
