SC10 4x4 Thread
Hi,
I'm a newb with belts. I just got my sc10 4x4 roller and I tore the front end apart, requiring me to pull the belt off. I got my servo in and now I went to torque down the clicker so theres 3 mm of bolt sticking out after the nut. When i do this its hard to turn the wheels and it's a little notchy. What did I do wrong? When the clicker is in "click" mode it moves freely and smooth. Is it my belt tension (it looks fine to me) or something else me rear slipper is locked down and the spur and belt are still turning so it's not my clutch. Any help would be very appreciated!
Thanks,
Dan
Thanks,
Dan
I love the 4000 and think its the best all around choice. Unless you are running a car that weighs over 6.5 lbs on a very large track you shouldn't need any more motor. If you are a "one motor needs to fit all tracks" guy, the 4600 can be dialed back to work anywhere, but it won't be able to match the throttle response of the 4000. I've let quite a few guys try my truck at one of the local indoor tracks that have the tekin 4600 in their trucks already and a couple of them walked into the hobbyshop and purchased the 4000 on the spot.
Ryan Lutz runs the 4600 in his Drango and he even turns down the end point quite a bit. I think too much is not a good thing with the 4600 unless you are a real pro at racing. You enter another factor in weather you change your gear or your end point on your radio to stay in control. Drivetrain destruction might be another factor with the 4600 with all the power it puts out.
DAN
The front belt drive pulley is two pieces that must be indexed properly before they will snap together completely with no gaps. There is a square drive on the toothed pulley and a mating square pocket on the pulley flange that absolutely must mesh together otherwise when you tighten the clicker nut completely the front assembly binds. When you loosen the clicker nut the assembly spins free but the pulley its not centered on the belt driveline.
Remove the belt cover and I bet you see a gap between the pulley and the left pulley flange. Fix this and all should be smooth again.
Hi,
Thanks,
Dan
Thanks,
Dan
Ok guys I pulled the clicker apart AGAIN (third time) and relized it was my bad, I switched those 3 long screws around and i put the longer one where it wasn't supposed to be and it was rubbing on the back of the flange deal things majiger. So I fixed that up and it's smooth! Getting my new castle 1410 hoplefully on Saturday. So maybe bring it to the track!!
I put a servo from my rc8be in it for the off season. Hs7955tg so I have a little bit of overkill on steering. I'm going to run the 1410 3800 on either a MM or a MMM. I'm going to start with 16/ 62? Anyway what do you guys think of this setup? Running on 2s.
Well the truck is finally completed and ready for the track, just have to finish setting up the RX8 with the laptop. Ran the truck (carefully) on the living room to center the steering and just had to punch the throttle at least once. The truck just about flippped over backwards, looks like the MTK basket is working already.
Thanks to all the members here for the mod ideas, posting photos of your trucks and inspiration to assemble a balanced setup that should work well on the track. I tried to route all wires as cleanly as possible, I'm happy with the final results. Credit goes to Furtado who is responsible for the saddle pack layout.
As a payback here are some photos of the final assembly to inspire others.
5Likes
