Like Tree5Likes
SC10 4x4 Thread
Old 10-30-2011 | 06:38 PM
  #9826
fastrc64's Avatar
Originally Posted by beaven
ran mine on the track this week there was a clicking noise under hard acceleration. i found the clicker was loose but that wasn't it so i checked the rear diff,there was very little lube in it so i corrected that. i also took out the 550 4000kv tenshock motor and put in a castle 4 pole 3800 540 motor as it felt overpowered. it was better but the noise came back. the belt tension feels good,any ideas? i have the basket set-up in the truck and other than the noise it runs fine......thanks
slipper is probably too tight and belts . i run with the over drive clicker up front
make sure that all your transmission case screws are not over tightened . if they are it will bind and make noise you might think that it is the belts . it happened to me once.
fastrc64 is offline
Old 10-30-2011 | 07:59 PM
  #9827
symmetricon's Avatar
just a FYI, i ran this weekend with the strc .5 rear hubs, and new tires, and i did seem to notice an increase in rear grip. I cannot say for sure that it was the hubs, but my truck had plenty of rear grip on a low/medium grip track.
symmetricon is offline
Old 10-30-2011 | 08:05 PM
  #9828
SourDieselX's Avatar
I will say, these Pro4 motors are the power houses. Between your motor and mine, I think we both had more power then any of the others on the track. I just ran like ass, lol
SourDieselX is offline
Old 10-30-2011 | 08:19 PM
  #9829
The Pro 4 is like cheating
Old 10-30-2011 | 08:20 PM
  #9830
lol, i think it was a losi who took me out in the main, haha
Old 10-30-2011 | 08:50 PM
  #9831
CraigMBA's Avatar
I had no idea how much chassis flex changed belt tension. Check it, no adjustments save me leaning on the shock towers.
Too tight:
Too loose:
CraigMBA is offline
Old 10-30-2011 | 08:59 PM
  #9832
Cameron Kellogg's Avatar
That is what makes the belt slip under braking. That is why the chassis brace is a good add on.
Cameron Kellogg is offline
Old 10-30-2011 | 09:06 PM
  #9833
CoyoteSlash's Avatar
Too tight:
[IMG][/IMG]
Too loose:
[IMG][/IMG]
It's good to see some pictures of what's going on on the track, Craig. Thanks.
Edit: You work on your Kitchen table too!?
Last edited by CoyoteSlash; 10-30-2011 at 09:15 PM. Reason: Didn't want to upset Fastlaps
CoyoteSlash is offline
Old 10-30-2011 | 09:09 PM
  #9834
CraigMBA's Avatar
After I made my chassis brace, the driveline got a lot quieter with no other changes, so I knew what happened. But I never checked the belt like I did in pictures, and when I did I was like OMFG.
CraigMBA is offline
Old 10-30-2011 | 09:15 PM
  #9835
I was able to run the belt tension a lot looser and not have the belt skip. When the chassis flexes like your top pic it will pull on the rear shaft also and it changes the gear mesh. Bad for 48 pitch gears.
Old 10-30-2011 | 09:37 PM
  #9836
What do u guys think of the sc10 4x4 rtr would it be any good
zenbonzakura is offline
Old 10-30-2011 | 09:42 PM
  #9837
Basically the same truck we all started out with but with AE's electronics.
Old 10-30-2011 | 09:49 PM
  #9838
SS LS1's Avatar
I'm currently setting up my new truck and did the same test after reading about it here, couldn't believe my eyes at how easy it was to get excessive belt slack from such little pressure on the shock towers.
I have a B44.1 saddle pack setup on the truck and I think the chassis flex is a lot worse without the stick pack brace/bracket. It flexes so easily that I wouldn't even run the truck until I made a chassis brace, which I did today. Looks like a chassis brace it's going to be mandatory for a saddle pack setup IMO.
I also noticed (as mentioned above) excessive belt tension really torques on the Topshaft and slightly twists the transmission, which in turn will affect gear mesh. I would be surprised if Associated does not include a chassis brace on a Factory Team kit in the future. This truck really needs one IMO.
I made the brace from some solid aluminum rod I had on hand and Rocket City ball end that are commonly used to make Clodbuster tubular suspension links. The hardest part was drilling and tapping the ends for the 6/32 studs to go into.
I had to keep the link level and up high enough so I can remove to saddled packs without removing the brace. I was concerned with the rear attachment point possibly breaking so I reinforced it with a large colored washer underneath and a locknut to spread out the load on the plastic over the motor. With the Tekin Pro 4 540 motor there is plenty of room above it to allow for some type of reinforcement piece add you can see in the last photo.
Now the chassis with saddle packs passes the chassis flex test Craig was trying above.
Attached Thumbnails SC10 4x4 Thread-img_20111030_134449.jpg   SC10 4x4 Thread-img_20111030_132904.jpg   SC10 4x4 Thread-img_20111030_133024.jpg   SC10 4x4 Thread-img_20111030_134126.jpg
SS LS1 is offline
Old 10-30-2011 | 10:15 PM
  #9839
BLbound's Avatar
Thanks for the pic Craig! Astonishing!
BLbound is offline
Old 10-30-2011 | 10:17 PM
  #9840
BLbound's Avatar
stick pack, but it will fit underneath the belt without a problem.
Thanks Symmetricon! I was also looking at that blue HW esc that looks like the orion r10pro esc...which I'm guessing is the same thing or very similar...
BLbound is offline
